Attic Renovation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-10-2010, 12:09 AM   #1
Attic Renovation
Hello every one I was wondering if is possible to convert my attic into living space. The space is 20x31 and if so how would it be framed1
extinct22 is offline   Reply With Quote
Old 10-10-2010, 07:59 AM   #2
Doubtful. Most codes require headspace of at least 7'6". Floor joists are probably 2x6, depending on the span need to be at least 2x8, or 2x10. Staiway space??? Emergency exit access???
Old 10-10-2010, 08:40 AM   #3
Rewards Points: 5,348
It looks lke you would need to raise the roof.
Ron
Old 10-10-2010, 10:17 AM   #4
The height in the center is 10 ft there are 2 pics here one of the top and one of the bottom. There are 2x6 24 OC ceiling 2x6 16 OC for the floor that I would change to 2x10. There is a window allready in the attic that goes out onto a porch roof and the stairway access would be done by comming through a closet over the stairs that go into the basement the only thing I guess is how would this space be framed if possble to do
Old 10-10-2010, 02:18 PM   #5
Here is another image of the window access that would be upgraded with a new window
Old 10-10-2010, 06:31 PM   #6
Registered User
Rewards Points: 526
Attic spaces are now be considered differently per Code: http://docs.google.com/viewer?a=v&q=...1txlzU01V4JQIg
Read up on converting it to living space, then ask your local Building Department their requirements: http://books.google.com/books?as_brr...G=Search+Books
Gary
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Attic fan options P550 Roofing/Siding 1 08-22-2010 12:47 PM
Attic fan options. P550 Electrical 6 08-22-2010 12:30 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Attic renovation the_watcher87 Building & Construction 1 12-27-2007 09:28 AM
