Attic Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-10-2010, 01:42 PM   #1
Unhappy
attic insulation
I am finishing a house. In insulating an attic that will not be used, is it ok to place plywood on top of the attic floor joists and place the insulation on top of the plywood. This would create a dead air space which I have read is a good insulator.
urbano is offline   Reply With Quote
Old 11-10-2010, 03:10 PM   #2
Rewards Points: 596
Insulation has many, many little dead air spaces in it. It's a far more effective insulation in the same amount of space. Why not simply blow in insulation, or use batts in between the joists? You can always stick more in on top of the joists.
operagost is offline   Reply With Quote
The Following User Says Thank You to operagost For This Useful Post:
urbano (11-11-2010)
Attic Insulation gruntman Roofing/Siding 12 12-04-2010 09:01 PM
Remove old attic insulation and critter mess? merlanvp Building & Construction 6 07-27-2010 04:36 PM
Attic insulation and soffit venting zacker Building & Construction 1 07-15-2010 10:17 PM
Finishing Attic, insulation question pjgsteelers Remodeling 1 07-13-2010 01:59 PM
adding attic insulation to existing insulation strouddljs General DIY Discussions 4 11-09-2009 05:06 PM
