Attic Conversion - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-21-2009, 02:49 PM   #1
Attic Conversion
I own a house built in 1920, and am considering converting the walk-up attic into living space. Today the space is used strictly for storage, and needs to be framed/drywall. I have read online about converting attic space, and people concerning themselves with reinforcing the joists. The attic I have already has a tongue and groove hardwood floor. It seems most of the projects I have read about where joists were reinforced there was not a "permanent" floor in place, rather just the open joists. I don't feel like ripping up the floor if it is not necessary. If anyone is familiar with building practices of that era-- if the hardwood floor was layed down at time of construction would it be relatively safe to assume the joists were constructed to support a floor and contents, rather than just hold the ceiling below? We are using the attic today for considerable storage and have not noticed any issues. Thank you.
American4Square is offline   Reply With Quote
Old 07-21-2009, 03:13 PM   #2
Rewards Points: 5,348
There should be no, "assuming", of anything in a project like this. All you need to do is check to see what the joist size is up there and compare it to the first and second floor.
What size joists do you have?
Ron
Old 07-21-2009, 03:18 PM   #3
Ron-- this may be a silly question-- but how can I tell the size of the joists without taking the floor up?
Old 07-21-2009, 03:30 PM   #4
You would need to verify the joist sizes, even if that means pulling part of the floor up
My 2nd floor is from the 50's & only has 2x6 joists
Which do not meet todays code for the spans they cover
Old 07-21-2009, 09:11 PM   #5
Registered User
Rewards Points: 526
Check the framing where you stick your head up into the attic, or at the drop-down stairs. Be safe, G
Old 07-22-2009, 06:18 AM   #6
If you can go to the edge of the floor and measure it. You can drill a 1/16" hole in a place that will not be seen and put a wire through the hole to the ceiling below. Subtract the thickness of the flooring and that's the joist width.
Ron
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
venting metal roof for attic conversion nelsonC Roofing/Siding 14 01-21-2010 02:32 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Attic Conversion and Venting jjmanes Remodeling 4 11-09-2005 01:51 AM
