Attaching Treated 2x4s To Basement Floor For Framing - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-26-2014, 10:42 PM   #16
Registered User
Rewards Points: 526
The foam stops the warmed wall from thermal bridging to the slab/earth temperatures. If you don't mind paying for more heat, omit the fb. Or if you KNOW there is a plastic vapor barrier (code required for last 40 years) under the whole slab, omit the fb or at least poly for the capillary break; http://www.greenbuildingadvisor.com/...-building-code
The greatest heat losses are at perimeter, though it is a small price for the savings at all interior walls, IMO, check with/out slab insulation; http://www.google.com/url?sa=t&rct=j...7c2C4A&cad=rja
If inspected, the steel nails in new pt wood won't pass, though I admit I did that 30 years ago...lol.
Gary
PS. I wouldn't use any pt wood in a basement I live in... with other choices available; http://publicecodes.cyberregs.com/ic...9_3_sec017.htm
"Naturally durable wood"; http://publicecodes.cyberregs.com/ic...9_2_sec002.htm
Old 03-28-2014, 07:47 PM   #17
Rewards Points: 422
Split drive anchor fasteners are what I liked using the best when doing my basement.
I got mine at a local hardware store that caters to the local contractors.
Here's what they look like http://www.grainger.com/search?searc...140328232832:s
Ramset comes in second place in my book .
Tapcons .....don't get me started.
High Gear is offline   Reply With Quote
Old 03-28-2014, 08:22 PM   #18
firehawkmph's Avatar
Rewards Points: 2,514
I've used my Ramset gun 99% of the time in basements with no issues. I always put sill sealer under the treated plate, not very hard at all. If you want you could use a hammer stapler and tack the sill sealer to the bottom plate while the wall is lying down. My second choice is tap cons with a cordless hammer drill. Very easy to use. You don't need a ton of fasteners either way. Your just pinning the bottom of the wall to keep it from moving. Also, they do sell pins for the Ramsey that are made to be used with treated lumber.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-29-2014, 10:26 AM   #19
bryanp22's Avatar
Rewards Points: 350
I used split drive with flat head. Just predrilled with a cheap hammer drill from harbor freight.
Sent from my iPad using Tapatalk
bryanp22 is offline   Reply With Quote
Old 07-18-2014, 05:05 PM   #20
Rewards Points: 31
Mike Hawkins
how far apart do the fasteners need to be when using the Ramset?
thanks!
ccleme11 is offline   Reply With Quote
Old 07-19-2014, 10:58 AM   #21
Knucklez's Avatar
Rewards Points: 1,002
similar idea with enhancement.. hammer two 16d nails simultaneously into the same hole. they bind together through friction and never move. 1/4" masonary drillit through wood into concrete first.
source: http://www.askthebuilder.com/attach-...oncrete-video/
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Prep to finish basement...Sub Panel? Thisgrub4u Electrical 14 01-07-2014 12:10 AM
Basement moisture/humidity issues amason2308 Remodeling 2 09-12-2012 09:27 AM
Basement partition walls - can they be framed without attaching to overhead joists? leitht Remodeling 5 01-10-2012 11:30 AM
Exception? to using treated sill plate for basement walls BriBri Carpentry 3 12-13-2011 05:11 PM
basement flooring suggestions? jeffro83 Flooring 2 05-14-2011 01:58 PM
