Attaching Swingset Bolt To Sistered Beam? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By daquix
Old 07-03-2019, 08:41 AM   #1
Attaching swingset bolt to sistered beam?
I have 2x10’s that I will be sandwiching together to make a big stiff beam for an adult swing set.
I’m about to put it together, but then I thought “how am I going to attach the bolts for swings into a sistered beam”? Because the boards are mated together, the bolt will want to push those boards apart, if bolted in the middle. And if I bolt to one beam, or the other, you don’t get the full strength - right?
daquix is offline   Reply With Quote
Old 07-03-2019, 09:13 AM   #2
retired framer
Rewards Points: 6,098
Re: Attaching swingset bolt to sistered beam?
Use three so you can screw in the center one. 4 nails every 12 to 16" from both sides and the beam is one.
Do not use flat bottom gables with scissor trusses.
Nealtw is offline   Reply With Quote
Old 07-03-2019, 10:11 AM   #3
JUSTA MEMBER
Rewards Points: 1,554
Get a bracket that holds the swing up.
The bracket is U shaped, designed to go over two boards sistered together.
Then the hang down part has a place to hook the swing into, with S hooks.
ED
Well phooey, I went searching for that, but only found this
https://www.ebay.com/itm/JGS-1800-Lb...QAAOSwQP5c2koN
Would this suffice?
de-nagorg is offline   Reply With Quote
Old 07-03-2019, 11:17 AM   #4
Rewards Points: 9,404
So, you mean you have a 10" long eyebolt that you want to mount in the center of a twin 2x10 beam ? You could make a couple of pieces 3/16" or 1/4" x 2-1/2" x 6" steel. Drill a clearance hole through the center for the eye-bolt. Maybe just a couple of 1/8" holes for nails to keep it from turning. A few coats of Rustoleum. One plate on the top of the beam and one on the bottom. Pre-drill vertical clearance hole through center of beam. Should be able to find the steel at HD or Lowes.
SPS-1 is online now   Reply With Quote
Old 07-03-2019, 12:00 PM   #5
Good idea. Thanks.
Wasn’t sure if i could use the bolt only.
Old 07-03-2019, 12:01 PM   #6
ED
Would this suffice?
Unfortunately not.
Need a bolt that goes to the top.
Swing may carry up to 300 pounds at times.
de-nagorg likes this.
Old 07-03-2019, 12:58 PM   #7
retired framer
Originally Posted by daquix View Post
Good idea. Thanks.
If you are doing a glider a 4 point hook is less likely to dump you out.
There are heavier ones like this.
https://cdn11.bigcommerce.com/s-q0zm...739570.jpg?c=2
Old 07-04-2019, 08:53 AM   #8
Rewards Points: 2,174
If you go all the way to the top, use a couple of these with a nut and a couple of bigass washers.
huesmann is offline   Reply With Quote
