Attaching Stair Stringers To Steel L Beam - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By trgerrity86
Old 08-08-2019, 11:23 AM   #1
Rewards Points: 14
Attaching Stair Stringers to Steel L Beam
I am remodeling my loft condo and moving the stairs from underneath the mezzanine/loft, to the open area of the unit. The end of the loft is supported by an "L" beam (pictures attached). The new stairs will lead up to the loft on the right side of the pictures (where the loft meets the concrete wall). There will be a railing to the left of the stairs. Given this is an L shaped beam and not an I beam, any ideas of the best method of attaching the stair stringers/header to the beam? I am meeting with my contractor to discuss but would love some other opinions.
Thanks!
Attaching Stair Stringers to Steel L Beam-img_1453-2-.jpg   Attaching Stair Stringers to Steel L Beam-img_1455-1-.jpg   Attaching Stair Stringers to Steel L Beam-img_1708.jpg   Attaching Stair Stringers to Steel L Beam-img_1706.jpg   Attaching Stair Stringers to Steel L Beam-img_1705.jpg
trgerrity86 is offline   Reply With Quote
Old 08-08-2019, 11:32 AM   #2
retired framer
Rewards Points: 6,270
Re: Attaching Stair Stringers to Steel L Beam
What is happening to the floor up stairs, you should have it extended over the top of the top riser?
Do not use flat bottom gables with scissor trusses.
Old 08-08-2019, 11:58 AM   #3
Rewards Points: 14
@neal - thats a good point - we were going to try to re-use the existing hardwoods up stairs
Old 08-08-2019, 12:06 PM   #4
retired framer
We usually just nail a 3/4" plywood to the face of the floor about 12 inches high
You may want to wait until you have done all the math and laid out the stringers so you can just to just what is needed. for the steel I would use elevator bolts as they will pull in to just about flush, you will want bolts going the other way thru the plywood for the 2x4 that goes under the top tread.
https://www.homedepot.com/p/Hillman-...1012/202242428
Old 08-08-2019, 12:36 PM   #5
Rewards Points: 14
Thanks Neal! One more question - are there any straps you prefer to use to tie together the wood stringers and the plywood/beam?
Old 08-08-2019, 12:41 PM   #6
retired framer
You nail thru the plywood into the back of the stringer and you nail the stringers into the 2x4 under the top tread, It ain't goin anywhere
And the bottom is also attached to the floor with a 2x4 behind the riser and the stringer is nailed to that.
The Following User Says Thank You to Nealtw For This Useful Post:
trgerrity86 (08-08-2019)
Old 08-08-2019, 12:51 PM   #7
Rewards Points: 14
Makes sense - thanks so much!
Old 08-08-2019, 12:58 PM   #8
retired framer
What are you going to do with the floor upstairs?
Old 08-08-2019, 03:54 PM   #9
Rewards Points: 14
I was thinking the plywood attachment would run up to same hight as the sub floor, then adding a piece of nose trim at the top. Would that work?
Nealtw likes this.
Old 08-09-2019, 12:30 AM   #10
retired framer
So you would have the plywood and the the finish riser and bring the nose over that.
Old 08-09-2019, 01:00 PM   #11
Rewards Points: 14
Yes sir!
One more related question - I would really like to side mount the posts for the railing that will run across the loft and tie into the stairs. I think that means that I would need to stack a pair of 2x6 or 2x8s and mount them to the outside of the beam so the side mounts have some meat to mount. Can I just run the 2x6's across and but them against the outside of the stair stringer, or is there a more creative way to do that?
Old 08-09-2019, 01:08 PM   #12
retired framer
Yes sir!
That is as good as any other method. Just make sure the bolts holding those boards will be close to where the railing posts will go.
