Attaching A Lot Of Wood To Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-22-2009, 12:12 AM   #1
Attaching A lot of wood to wall
I want to take a whole lot of scrap wood of various sizes from 2ft x 2ft down and attach them in a random pattern to a wall that is roughly 12x8. I plan to cover the entire wall with scrap wood of various stains, colors, sizes, and types.
The thing I am worried about with this is expansion and contraction. How can I attach these so that I don't have pieces falling off in a year? I do not want to ruin the front of them with screws, although maybe stainless screws would look nice. I am open to suggestions.
Thanks!
MakinItHome is offline   Reply With Quote
Old 08-22-2009, 09:38 AM   #2
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 844
I haven't done anything like that before, but if I were going to do it, I would treat the wall like a floor on which I wanted to install a parquet floor (I'm assuming this is inside). I'd look into putting up plywood on the wall, then shaving the scrap pieces down in thickness a ways, like 3/4", and then glue them onto the plywood using wood floor glue. Just like if you were gluing wood parquet down. I'd also probably have a pneumatic brad or finish nailer handy, and throw some nails in. Sort of toe nailing the scrap pieces to the plywood/stud, on an angle so you wouldn't see the nail holes.
If wood floor glue can hold parquet down to a floor, I'd think it would do the trick for a wall.
Aggie67 is offline   Reply With Quote
Old 08-22-2009, 10:16 AM   #3
I assume this is an inside wall?
Sort of an artistic look?
The plywood/glue sounds like a good idea
If just sheetrock is up there right now I'm not sure it will hold
Old 08-22-2009, 06:44 PM   #4
Yeah it is an interior wall. Right now the wall is original plaster. So just to be sure I have the procedure right I should screw some 1/4 or thinner plywood to the wall and then use wood floor glue and finish nails to attach the pieces. Can I make this all tight to each other and tight against all the edges at the floor, ceiling and walls?
Old 08-22-2009, 07:26 PM   #5
Rewards Points: 150
Makin it Home
I am getting a feeling that you are worried about expansion and contraction.
With pieces as small as you have the mount of expansion and contraction will be minimal. I would say that you would probably be okay butting them tight but you could give them a minimal expansion gap as 1/8" or so would probably be more than sufficient.
I am not going to comment on the methods that are out there as they are numerous. You could do a parquet look you could do a random lay the design possibilities are endless as is the method of attaching them to the walls but like I said as far as expansion and contraction I would not worry about it too much.
Good luck and be safe!
Paragon is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Attaching Floor Joist To Solid Core CMU basement wall jrepp Building & Construction 5 04-23-2009 02:57 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 12:28 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
