Attaching Girder Truss To Existing Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By Jda130
Old 09-27-2017, 10:18 AM
Rewards Points: 16
Attaching girder truss to existing roof
I am using LUS26 clips to attach existing trusses to girder truss. The LUS26 are insetted under the existing trusses already and I'll have to cut the roof from the top to nail them to the girder truss. The problem is that I have like an inch gap between the girder truss to existing truss studs and will be difficult to attach them; how can I get the girder truss more flush to house? I dont want to force push it in and nail it because it might pull the existing house trusses out creating a bigger problem. Is there a way to make this work? Help please.
Attaching girder truss to existing roof-20170927_064732_1506521872880.jpg   Attaching girder truss to existing roof-20170927_064801_1506521889839.jpg
Jda130 is offline
Old 09-27-2017, 11:50 AM
retired framer
Rewards Points: 6,086
Re: Attaching girder truss to existing roof
Pull the girder and nail another bottom cord on that side. Nail the crap out of that. cut all the other trusses to the same length.
This should be cleared by the engineer. If you clear it with the truss company, you need paper work for it.
Jda130 likes this.
Nealtw is online now
The Following User Says Thank You to Nealtw For This Useful Post:
Jda130 (09-27-2017)
Old 09-27-2017, 01:16 PM
Rewards Points: 16
Thank you for your reply Nealtw. I went back to see the plans and noticed that I am supposed to add a new 2x6 block behind the girder truss; is this the same thing as you were refering? Also the plans says new 2x6 block; is it suposed to be cord as you explained in your reply? I've posted pic. And finally what size nails should I use to nail them? Thank you very much.
Jda130 is offline
Old 09-27-2017, 01:26 PM
retired framer
They have used a different language. Not sure why they use the word Drag.
I think the block is meant as a short piece to give the girder a bigger footprint on the wall
but here that would have been written like 2x10 x 2ft block.
I would call the truss company and ask for the guy that did your plans and ask him what to do. They may not want you to cut any more off the old trusses and then you would just use short blocks where needed.
Jda130 (09-27-2017)
Old 09-27-2017, 02:30 PM
Rewards Points: 16
Alright, thank you. I was on panic mode that I had ruined everything. I feel a lot better now and will contact the truss company for advise. Thank you.
Nealtw likes this.
Jda130 is offline
Fascia board/soffit roof truss rotten. HELP. breakerboy2000 Carpentry 2 03-04-2013 07:17 PM
Roof over existing roof Rammertime Roofing/Siding 9 05-25-2011 09:09 AM
Joining deck roof with existing roof Badur Roofing/Siding 1 03-27-2011 03:47 PM
Tie a shed roof into existing 6/12 roof jj1122_2000 Building & Construction 1 02-18-2009 10:37 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
