Attaching Cantilever Balcony - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2009, 01:39 PM   #1
Attaching cantilever balcony
I'm building a grarage using box trusses, in order to put a small apartment upstairs. I would like to build a balcony off the gable end side of the apartment using the cantilever design (I don't want to use support post). Is it possible to do this if my floor joists (which are the bottoms to my truss) are running perpendicalar to where the balcony will extend?
vtboy51 is offline   Reply With Quote
Old 08-17-2009, 07:58 PM   #2
SNC
it is possible. but your balcony joist need to extend back into the building.
http://www.housingzone.com/article/CA6272510.html
scroll down to the third diagram.
SNC is offline   Reply With Quote
Old 08-17-2009, 08:36 PM   #3
If i was framing my second floor normally this would be an option, but I am using a box truss, so the floor joists are already built (since they are part of the trusses), do the truss companies have some way to build their box trusses with this option, or would i have to modify the trusses after I get them from the factory?
Old 08-18-2009, 05:44 PM   #4
Rewards Points: 5,348
That would be the question to ask the truss company.
Ron
Old 08-18-2009, 06:03 PM   #5
SNC
you frame with trusses the same way you frame with joists.
if your truses are already built, then that what you have.
they can be cut and modified but i could not explain that over a computer and with out seeing everything.
sounds like you should have thought of this before ordering the trusses
untreated lumber for cantilever joist for balcony hebrewdiver Building & Construction 6 05-10-2009 10:32 PM
Attaching deck ledger to cantilever ram80ran Building & Construction 13 04-18-2009 12:29 PM
Ranch to cantilever 2 story? Badfish740 Remodeling 3 01-04-2009 04:14 PM
balcony delema onthelevel Carpentry 2 09-13-2008 10:53 AM
wooden balcony in living room Lorac Building & Construction 1 07-24-2004 03:33 PM
