Attaching 4x4's Lengthwise To Each Other - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-07-2009, 03:04 PM   #1
Attaching 4x4's lengthwise to each other
If installing a support 4x4 column that will be approximately 16' long, can I use available hardware to connect (2) 8' 4x4's rather than use (1) 16' 4x4? The (2) pieces will always be in compression but I don't know if this is an accepted method of doing this or not. Columns will be supporting a cantilevered upper deck on a house. Please advise.
CHARLIEBUB is offline   Reply With Quote
Old 07-07-2009, 03:07 PM   #2
Use a 16' 4x4
Better to use a 4x6 or larger as 4x4 will warp & twist
There is more then just compression load on these
Old 07-07-2009, 03:56 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You had better look into the building codes. It isn't very likely the code will allow even a solid 4X4 to go that length to support an upper level. I'm sure a spliced [anything] would be out of the question also.
Old 07-07-2009, 04:19 PM   #4
I think I would go with a 6 X 6, start with two 10 footers, lap cut, glued and bolted but I think a single 16 footer would be cheaper.
hayewe farm is offline   Reply With Quote
Old 07-07-2009, 06:51 PM   #5
Originally Posted by Scuba_Dave View Post
Use a 16' 4x4
Thank you for the info. I will most probably go with a 16' 4x6 to avoid twisting, etc.
Old 07-07-2009, 06:52 PM   #6
Thank you for your info. I will most probably go with a 16' 4x6 to avoid twisting, etc.
Old 07-07-2009, 10:30 PM   #7
Registered User
Rewards Points: 526
If your local Building Department is using the 2006 (most recent code), a 4x6 will not work. A 6x6 will go to the bottom of the deck joists--- 14' maximum. Anything taller has to be a larger post. Here is the code to date, bottom of page 7: http://www.awc.org/Publications/DCA/DCA6/DCA6.pdf
I suggest you ask your local building department as code acceptance varies locally.
Notice the ledger bolt requirements as well. Don't let this happen: http://www.nadra.org/industry_news/april07_woodbits.pdf
Be safe, G
Garage storage, attaching to engineered beams jdcook72 General DIY Discussions 6 06-16-2009 11:01 PM
Attaching Drywall to 4" of Rigid Foam PerpetuallyRepairing Drywall & Plaster 9 02-19-2009 05:24 PM
Attaching Studs to Concrete/Which way mjkpainting Carpentry 17 12-30-2008 10:02 AM
Attaching Lower Cabinet Moulding? GearHd6 Remodeling 8 11-23-2007 10:42 AM
