Any Trick To Putting A Chimney Through Vinyl Siding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-24-2011, 07:53 PM   #1
Rewards Points: 264
Any trick to putting a chimney through vinyl siding?
I am installing a wood burner. I wanted to get a through-the-wall chimney kit, but they are ridiculously priced (over $300!)
Is there anything special I need to do, or do I just cut a hole with a recip saw?
What is the best way to keep the hole from leaking? Should I use silicon, or would something like roof patch work better?
tibberous is offline   Reply With Quote
Old 09-24-2011, 08:32 PM   #2
You should spend the $300 for the kit. Its designed so that the weather is kept out and the house doesn't burn down.
Old 09-24-2011, 10:03 PM   #3
Rewards Points: 264
$300 though? That's a lot of money to put a pipe through a wall.
Besides, I'm broke - my plan for heating my house this winter is to burn things I find for free: Craigslist stuff, dead trees, abandon wood buildings, cardboard... pretty much anything I can get without having to drive real far.
Old 09-25-2011, 12:04 AM   #4
Keep in mind that if your place burns down, with you in it; you'll be a long time dead!
Sometimes in life we can cut corners, but the heating system for your home isn't one of them.
Old 09-25-2011, 07:02 AM   #5
Rewards Points: 3,130
I'm afraid you have no idea what you're doing. Spend the $300 and do things right. An improperly installed chimney connector is quite dangerous.
What sort of chimney do you have that you want to connect to? You can't just run a pipe through your wall and call it good. For safety and proper draft, you must have a chimney the goes up above your roof line. That alone will cost a whole lot more than $300. If you're as broke as you say, I'd figure out a Plan B.
Old 09-25-2011, 07:36 AM   #6
Rewards Points: 264
Really?
I was just planning on sticking the pipe horizontally out through the wall, with just enough slope that rain wouldn't run down it. I was thinking about maybe adding a screen to keep birds / leaves out.
Old 09-25-2011, 08:37 AM   #7
Old School
Willie T's Avatar
For cryin' out loud, it takes you a few days of work to set aside enough to do the job right and safe. DON'T SCRIMP on something you aren't fully knowledgeable of. You're paying for their expertise and research and testing, qualifying the product for the necessary safety regulations, as well as just the materials.
Do you go cheap on tires and brakes for your wife's car?
Willie T
Old 09-25-2011, 08:41 AM   #8
the Musigician
DangerMouse's Avatar
Really?
Absolutely! Please heed md2lgyk's advise.
Your safety comes first!
DM
Old 09-25-2011, 08:45 AM   #9
the Musigician
That would depend upon any number of things..... how she drives.... how much she drives.... where she drives..... how much you'll collect from the insurance policy....
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Willie T (09-25-2011)
Old 09-25-2011, 10:06 AM   #10
Rewards Points: 5,348
Really?
This would would fall into the "cheap, stupid" catagory of home renovation practices. Where the homeowner has no understanding of the consequences of his actions. Is then explained what they are and still proceeds with his course of action.
If this is what you plan, I can save you even more money. Use a cardboard sonotube for the vent through the wall.
You'll only be using the wood stove one time anyway.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
rossfingal (09-25-2011)
Removing vinyl trim around entry door without breaking vinyl siding 2vets Building & Construction 1 10-18-2010 11:28 AM
Vinyl siding over old 12" lapboard siding Michael1960 Building & Construction 1 09-16-2010 10:32 PM
How to mount an enclosure to exterior wall with vinyl siding? biglaz Building & Construction 3 05-30-2009 11:13 AM
vinyl siding over wood siding loyal Building & Construction 6 05-26-2009 01:17 AM
Replacing Wood Siding WIth Foam Backed Vinyl xludan Building & Construction 1 05-21-2009 07:27 PM
