Any Threads About Building A Detached Garage? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-08-2015, 08:44 PM   #1
Rewards Points: 169
Any threads about building a detached garage?
Hi Guys,
I'm thinking about building a detached garage in my backyard and not sure where to start.
I did a few searches here, but couldn't find any posts that talked much about it. Maybe I was looking in the wrong forum, but thought I'd ask here to see if anyone knows of any posts documenting a garage build? I didn't see anything in the project showcase section either.
Thanks for any help!
52Caddy is offline   Reply With Quote
Old 09-08-2015, 08:48 PM   #2
Wayne1971's Avatar
Rewards Points: 2
Originally Posted by 52Caddy View Post
Hi Guys,
you first need to decide if you want a concrete floor or do you want to build it like a pole barn
Sent from my XT1097 using Tapatalk
Wayne1971 is offline   Reply With Quote
Old 09-08-2015, 08:52 PM   #3
Rewards Points: 169
I'd be going concrete.
I'm hoping to find some post that talk about costs and designs and such.
Old 09-08-2015, 09:04 PM   #4
Wayne1971's Avatar
Rewards Points: 2
You can go to a home improvement store and get a book on different designs and they have pre planned designs with the cost and materials needed
Old 09-08-2015, 09:25 PM   #5
Rewards Points: 5,348
There are websites all over the internet about garage plans. Pick one you like. Build it, or have it delivered on the base you want. Cost vary with design and build type.
If your locale requires plans and permits, look into it.
Think of it as the DIY part of the project.
Ron
B. Franklin 1759
Old 09-08-2015, 11:02 PM   #6
Rewards Points: 6,652
52caddy go to your county and get the Platt for your property, that shows lot lines and where the setback is allowed. Also get height requirements and if they limit the size of the garage.
If you want to get ideas, go talk to your neighbors if any have detached units. You can actually order the units per spec and walls pre made, so that all you have to do is lift and secure, then put up the trusses and start putting on the plywood. If you have enough people, you can actually get one up in a Weekend, where the Plywood is covered with the Tyvek and the Shingles are on the roof. Then you can spend another weekend getting the siding on, door installed and sit back to enjoy.
Old 09-08-2015, 11:06 PM   #7
If you just do a search for "Garage Plans". you can choose at your leisure.
Old 09-09-2015, 12:20 AM   #8
Rewards Points: 50
Hi Guys,
think there are lots of posts over here...
http://www.garagejournal.com/forum/forumdisplay.php?f=7
jcrizzy is offline   Reply With Quote
Old 09-09-2015, 03:49 PM   #9
47_47's Avatar
Rewards Points: 320
I just got through building a 36'x 28' detached. You first need to do this ^^^. The actual deciding on what style, size... was the hardest part. Take a drive around for the different styles or look at actual plans for ideas.
Lot of helpful folks here as far as the construction, but you need to first decide what you can and want to build.
47_47 is offline   Reply With Quote
detached garage sub-panel?? Master Brian Electrical 15 10-07-2013 07:06 PM
Detached Garage Subpanel + Generator Back Feed insaneirish Electrical 3 09-06-2011 03:09 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 10:07 AM
