Another Load Question - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By Nealtw
  • 1 Post By TarheelTerp
Old 12-09-2018, 08:31 AM   #1
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,470
I'm thinking about more stuff for my garage project again.
(stuck inside with 'historic snowfall' will do that)
The building is 24x16 with 2x4 trusses on 24" centers across the 16' width.
< ---X---------X---------X---------X----------X---------X--- >
Questions:
1) How much weight can typically be supported off one bottom chord?
2) And with something (2x8?) spanning THREE bottom chords?
(I'm thinking about a chainfall/hoist and motorcycle or jet ski engines)
TarheelTerp is online now   Reply With Quote
Old 12-09-2018, 08:45 AM   #2
Guapo
Rewards Points: 11,950
Re: Another Load Question
https://www.selecttrusses.com/truss-calculator/
Truss load calcuator
Guap0_ is offline   Reply With Quote
Old 12-09-2018, 08:48 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 814
In general, trusses can support their own weight plus sheetrock. That is what the truss manufacturer will make clear to you. Of course with center span support, they can handle much more, but I would be reluctant to test it.
Will the chain fall be on a rail or stationary? Would not a swingset type support work? Some are on rollers and some just come apart after use. Just a suggestion.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 12-09-2018, 08:59 AM   #4
retired framer
Rewards Points: 4,538
How much weight? and after you have it set up and something else comes up, how much is too much?
Old 12-09-2018, 09:13 AM   #5
MarginallyQualified
Thanks for all the warnings...
IF, a big dam if, I do this it would be at a single spot and not on a rail...
(a rail/beam probably weighs more than a MC or JS engine).
The whole point (IF I do it at all) is to NOT have something else in the space.
Old 12-09-2018, 09:26 AM   #6
retired framer
I am sure it would be no different than a 200 pound man walking around up there when the roof was assembled, I would still add ply wood gussets from the bottom cord to the top cord so you are using the strength of the top cord.
TarheelTerp and chandler48 like this.
Old 12-09-2018, 10:56 AM   #7
MarginallyQualified
There ya go... that's the sort of information I'm looking for. Thanks Neal.
Nealtw likes this.
Old 12-09-2018, 10:59 AM   #8
retired framer
Not sure it is even a consideration when some one hangs a chandelier.
Question about generator ready load centers Killavolt Electrical 0 07-01-2016 12:26 PM
meter/main combo to load center grounds and bonding? ronsquery Electrical 2 03-16-2013 06:29 AM
Load bearing wall removal question... Huggins90 Building & Construction 17 01-21-2013 11:07 AM
Main load center switchout question fdmillion Electrical 15 01-17-2013 08:23 PM
Calculating load - 240 load question jamiedolan Electrical 5 10-04-2008 06:26 PM
