DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Building & Construction (https://www.diychatroom.com/f19/)
-   -   Another Load Question (https://www.diychatroom.com/f19/another-load-question-648049/)
TarheelTerp 12-09-2018 08:31 AM
I'm thinking about more stuff for my garage project again.
(stuck inside with 'historic snowfall' will do that)
The building is 24x16 with 2x4 trusses on 24" centers across the 16' width.
< ---X---------X---------X---------X----------X---------X--- >
Questions:
1) How much weight can typically be supported off one bottom chord?
2) And with something (2x8?) spanning THREE bottom chords?
(I'm thinking about a chainfall/hoist and motorcycle or jet ski engines)
Guap0_ 12-09-2018 08:45 AM
Re: Another Load Question
https://www.selecttrusses.com/truss-calculator/
Truss load calcuator
chandler48 12-09-2018 08:48 AM
In general, trusses can support their own weight plus sheetrock. That is what the truss manufacturer will make clear to you. Of course with center span support, they can handle much more, but I would be reluctant to test it.
Will the chain fall be on a rail or stationary? Would not a swingset type support work? Some are on rollers and some just come apart after use. Just a suggestion.
Nealtw 12-09-2018 08:59 AM
How much weight? and after you have it set up and something else comes up, how much is too much?
TarheelTerp 12-09-2018 09:13 AM
Thanks for all the warnings...
IF, a big dam if, I do this it would be at a single spot and not on a rail...
(a rail/beam probably weighs more than a MC or JS engine).
The whole point (IF I do it at all) is to NOT have something else in the space.
Nealtw 12-09-2018 09:26 AM
I am sure it would be no different than a 200 pound man walking around up there when the roof was assembled, I would still add ply wood gussets from the bottom cord to the top cord so you are using the strength of the top cord.
TarheelTerp 12-09-2018 10:56 AM
There ya go... that's the sort of information I'm looking for. Thanks Neal.
Nealtw 12-09-2018 10:59 AM
Not sure it is even a consideration when some one hangs a chandelier.:biggrin2:
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
