Thread Tools | Display Modes |
#1 |
Rewards Points: 6
![]() Additional Bedrooms
Hello everyone, it's been a while since I've posted on forums, and the first post on this one in particular. Anyway, we have a project and are unsure of how to proceed, and this seemed like a good place to ask for help!
I have an addition off of the side of my house, currently closed to the house itself, with access via doors on both the front and back of the house. Currently it is used as a shop/ tool storage/ junk storage area, but we're thinking that it would make a good space for 2 extra bedrooms. This would mean we'd be opening up a doorway on the exterior wall of the house that joins to the addition, but that's a battle for another day, what I really want to find out first is if it is even a good idea. The framing was done sometime in the 80's I believe (we've owned the house for 2 years now), and it's done with 2x4's on 24" centers. I was told by the lumberyard manager that I should add 2x2's to the studs and both top and bottom plates to make it 2x6 framing. That's all good, but I'd like to get some more insight before I tackle this project. What's currently built seems sloppy to me, (note the glass door was installed with hinges facing out...) and am not sure if I should be knocking it out and starting from scratch or what.. Please reference the pictures, and any insight is much appreciated! |
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 144
I would not listen to the lumber store guy to even buy a nail.What what would adding a 1X2 to the walls do?
You will first need a permit.In order to obtain one you will probably need some kind of structural drawing .Is the present building on a slab on grade or on a foundation with footings? this would be your first concern. It would also help if we knew what part of the world you were in? |
Advertisement |
#3 |
Rewards Points: 6
Oh right, I live in Saskatchewan, Canada... Winter is a concern. So far as I can tell it sits on a 4 or 5" concrete slab, no discernible grade. The lumber dude said that I could turn the exterior walls into 2x6 framing by adding 2x2's to the current 2x4's.. for strength and additional/ better insulation.
Advertisement |
#4 |
Rewards Points: 144
The lumber dude is full of BS.You can add the additional width to the studs to make them 2x6 but what do you have under the slab to support the structure?
#5 |
Rewards Points: 18,118
Is there no codes in you area?
Adding a bedroom opens up a whole can or worms in the US, zoning and the heath dept. get involved. http://www.cmhc-schl.gc.ca/en/co/grho/grho_010.cfm There's not even close enough room in the ceiling for enough insulation and proper venting. That deck also was built to high and is just going to cause water damage. In you area it should have been at least 6" below the threshold.
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
The Following User Says Thank You to joecaption For This Useful Post: |
Mingledtrash (02-17-2016)
#6 |
Stairguy
Rewards Points: 508
More room for insulation. Yes. More strength, absolutely not. Best bet is to get a competent contractor to give you an idea of what needs to be done. It's all about the existing structure and what it can handle
#7 | |
Rewards Points: 1,036
![]() Quote:
#8 | |
Rewards Points: 6
![]() Quote:
Advertisement |
Tags |
addition
bedroom
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Wiring for Additional Lamp Posts in Backyard | bloopy87 | Electrical | 2 | 10-19-2015 12:30 PM |
Routing Additional Return Duct | robert.juric | HVAC | 14 | 06-27-2012 04:20 PM |
Furnace not heating bedrooms. Bleed pipes? | Sally May | New Member Introductions | 2 | 11-30-2010 09:00 PM |
Subpanel for bedrooms | Xavier Thomas | Electrical | 4 | 04-01-2010 10:16 PM |
Adding additional landscaping | steel | Landscaping & Lawn Care | 4 | 06-14-2008 02:25 AM |
