Addition/chimney Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-07-2009, 10:18 AM   #1
Addition/chimney question
Hi all,
We want to build an addition (which will consist of a garage with a bedroom and bathroom on top) on to the side of our house. Our house is a raised bungalow. Currently, we have a chimney on that side of the house (it is outside but attached to the side of the house). When we put the addition on, the chimney will be inside (instead of outside) and the addition will be about 4 feet higher than the old part of the house.
What will we need to do to the chimney? Can it just be extended higher or will we need to have a brand new chimney installed?
Thanks!
mrbowma is offline   Reply With Quote
Old 06-07-2009, 01:54 PM   #2
Rewards Points: 95
masonry chimney?
NJ Brickie is offline   Reply With Quote
Old 06-07-2009, 03:05 PM   #3
Yes, bricks with a liner
Old 06-07-2009, 06:07 PM   #4
Is the chimney liner a ceramic one?
If so, its possible to add on to the top of this!
However, if its a continuous metal liner it will likely have to be replaced, as I don't believe these can be spliced.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
