Adding Venting Duct? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2014, 08:57 PM   #1
Rewards Points: 358
I am really not sure which section to add this in, so if mods must move this I apologize in advance.
We have a space saver microwave over our electric stove.
The biggest complaint we have about this is that it does not vent to outside, it just recirculates through a filter and blows it back into your face, which really does nothing.
Our microwave needs to be replaced, so when that happens I would like to try to add a vent to the outside. The problem with this is the location of the microwave, it is located directly in front of my breaker box, and main power line in from the city. Not to mention under the eve. Here are a couple more pics.
Now most of the vents I see go directly out the wall, but I am not sure if this is possible in my case. Is going though the roof the only option in my case, and then I can box around the ductwork above the cabinets?
cbzdel is offline   Reply With Quote
Old 09-03-2014, 09:36 PM   #2
Rewards Points: 996
angle the pipe over either way inside the cabinet. then out the wall.
Fix'n it is offline   Reply With Quote
Old 09-03-2014, 10:14 PM   #3
Rewards Points: 358
Is a certain type of vent required for this, or is it the same thing as a dryer vent?
Or does it also depend on the appliance itself?
Old 09-03-2014, 10:48 PM   #4
Rewards Points: 996
i am going to get one of these, when i do mine.
http://www.luxurymetals.com/wind-proof-wall-vent.html
Old 09-04-2014, 10:44 AM   #5
Rewards Points: 358
Between a wall and roof vent, is there a reason to choose one over the other?
I am really worried about going into the wall with the power box right there, I am worried the wall there is just full of electrical lines, not to mention drilling though hardie siding is a pain in the butt haha..
Old 09-04-2014, 09:13 PM   #6
Rewards Points: 996
i don't know anything about going through the roof. someone else will have to help there.
but i don't see why it can't be done.
Ridge Cap Venting Issues - Poor Ventilation?? askeyb Roofing/Siding 16 03-29-2016 05:05 PM
Duct Fan Relay Question Burbman HVAC 4 03-13-2013 08:34 PM
Adding Return Air Duct in Master Bedroom ajlewis1 HVAC 10 08-14-2011 05:33 PM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 07:20 AM
Adding new duct/Register CEbury HVAC 1 06-25-2008 11:51 AM
