Adding Sink - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-21-2012, 10:31 AM   #1
adding sink
I have a 2 story home and I am adding a 2nd sink to the master bath on the 1st floor. Will it hurt the stability of the structure if I drill thru the 2x4's to insert the additional line to connect a 2nd sink?
gonmo is offline   Reply With Quote
Old 05-21-2012, 03:08 PM   #2
Pictures?
If you look through archives, I added a second sink on my first floor master bath as well.
But post some pics, it will make giving you advice a lot easier....
Wiscbldr is offline   Reply With Quote
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 08:29 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
How bad/unusual is it for a kitchen sink under window to be off-center? Iron Petunia Remodeling 17 11-21-2010 06:33 AM
adding an additional bathroom sink wbeaulac Plumbing 4 10-22-2010 11:17 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
