Adding A Rollup Door To A Shed. - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By joecaption
Old 09-11-2016, 01:19 AM   #1
Rewards Points: 14
Adding a rollup door to a shed.
I've found a shed kit that i've found at our local hardware store but the wall height on the pre-built frames are a little short for what i want to do. I'm looking to take the swinging doors that it comes with and replace them with at 4'x7' roll up door. I've ran into a problem where i'm probably going to need to make the sidewall at least 24" taller on both sides. Is there a way to add 24" to both sidewalls. I'm not able to special order a taller frame in the width i'm alloted. To me this sounds like a silly question but i'd figure id ask to make sure its possible.
Gorilla03 is offline   Reply With Quote
Old 09-11-2016, 08:45 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 29,542
Re: Adding a rollup door to a shed.
Does the shed include a floor? If not then add a 2 foot stem wall to concrete pad.
Old 09-11-2016, 08:49 AM   #3
Rewards Points: 14
Yes, the frames have a 2"x4" treated base
Old 09-11-2016, 08:57 AM   #4
Rewards Points: 14
These are the frames I will be using:
https://www.menards.com/main/buildin...4448800283.htm
Old 09-11-2016, 09:10 AM   #5
Rewards Points: 18,118
Just not a great plan to build a shed that close to grade, it's going to take out the sheathing, floor joist and the subfloor.
There's been hundreds of post on this site and any DIY asking how fix these issues after it's to late.
No way would I want to use just 2 x 4's for floor joist unless I was just building a 4 X 4 shed.
Stick build this yourself instead of buying a kit and you can have the wall height any length you want.
de-nagorg and ReelDeel like this.
rjniles (09-11-2016)
Old 09-11-2016, 09:30 AM   #6
JUSTA MEMBER
Rewards Points: 372
Yes build it yourself. It is not hard, and you get exactly what you want, without having to modify some "kit".
And as a bonus you get to pick your own lumber for it, that is straighter and better than any crap picked by the "experts" at the store.
I've had to return lumber that was delivered by them that was too crooked to build with, so I always get my own.
There are hundreds of plans available that you can adapt to your ideal shed.
ED
de-nagorg is offline   Reply With Quote
Old 09-11-2016, 04:31 PM   #7
Super Moderator
joed's Avatar
Check with your local truss supplier also. Around here they have standard trusses your buy without pre order for small sheds.
Solar For Shed? dezandseth Electrical 3 08-12-2013 10:25 AM
Conduit questions in shed wiring TheCowGod Electrical 28 03-18-2012 02:42 PM
Zoning issue with planned shed Ler0y Jenkins General DIY Discussions 15 02-01-2012 01:41 PM
unsafe wiring to shed? lawsklsux Electrical 7 11-14-2010 01:16 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
