Adding Partition Wall In W-t-wall Carpet Greatroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 11:59 AM   #1
Adding partition wall in w-t-wall carpet greatroom
want to add 4' high by 12' long partition wall in greatroom, (vaulted ceiling), which has wall-to-wall carpeting. Have a vertical bulkhead to fasten one 4' end of wall. the opposing end will be free-standing except for the base/sole/footer. This is basically for deco, to break down the greatroom's floor area. (partially sectionalize) will the wall be too unsecure? will the sheetrock give it some stability? will the joists underneath, (in the crawlspace), need to run horizontal or perpendicular to the proposed wall?
ernie.albrecht is offline   Reply With Quote
Adding support to a wall, need to reroute waste pipe and more sdrzewic Building & Construction 2 08-23-2010 12:16 PM
partition wall big rob Carpentry 12 08-22-2010 05:47 PM
Partition wall in garage pomelo Building & Construction 7 11-23-2009 09:46 PM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 08:35 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
