Adding Garage To Back House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 03:07 PM   #1
Adding Garage to back house
I am adding a 12X15 Garage to the back of my home. I live in the midwest and know I need a frost footer. I will be using two sides of my existing home. I will tie the floor into the existing foundation. Do I also need to tie the new footing into the existing footing all the way down? The garage floor will be on the same grade level as my current basement floor which is a walkout.
klaffey is offline   Reply With Quote
Old 04-19-2011, 03:15 PM   #2
Concrete & Masonry
Rewards Points: 462
Will the two footings be at the same elevation? If so, dowelling them together is easy to do and would be a good idea.
jomama45 is offline   Reply With Quote
Old 04-19-2011, 03:41 PM   #3
Yes the footings will be at the same level. Do I drill into the existing footing and if so, how deep and do I use rebar and epoxy to secure? Also how how many do I need?
Old 04-20-2011, 10:32 AM   #4
Concrete & Masonry
Rewards Points: 462
Personally, I think the epoxy is overkill, but I don't know what the actual soil conditions are, nor am I an engineer. I would put 2-3 5/8" dowels (about 16" long) into each footing, drilled at least 6" deep.
Adding a small "roof overhang" to back of garage? CoconutPete Remodeling 7 06-18-2010 01:19 PM
Paint fumes in house from garage burnt03 General DIY Discussions 5 03-15-2010 10:53 PM
Garage framing rotted, back side dropped 3" zetti1102 Building & Construction 12 08-06-2009 09:18 PM
Adding A Garage kmb997 Building & Construction 4 07-17-2009 04:28 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
