Adding Foam Board To Exterior Wall Cavity - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 07:26 AM   #1
Rewards Points: 330
Adding Foam Board to Exterior Wall Cavity
Still have to talk to the county building department about this, but need you thoughts.
While I have an exterior wall open (from the interior), I want to add a piece of 3/4" foam board in contact with the exterior sheathing. The seam along the studs will be sealed. Then kraft faced insulation will be re-installed. The framing will then be covered with required thickness sheetrock.
Are there any thermal, vapor, or moisture issues with this configuration?
Earnie is offline   Reply With Quote
Old 02-23-2010, 08:27 AM   #2
Put your location in your member profile.
Vapor barriers depend on climate and location.
Properly installed kraft facing IS a vapor barrier.
Dairylander is offline   Reply With Quote
Old 02-23-2010, 09:27 AM   #3
Rewards Points: 330
Central N.C.
Old 02-24-2010, 01:11 PM   #4
Rewards Points: 330
Yes, kraft faced insulation will be installed. I'm wanting to know if there are any issues with having the foam board behind the insulation and against the exterior sheathing?
Installing deck ledger board over foam board? RickT Building & Construction 9 04-27-2018 11:41 AM
Hardiboard siding over Rigid Foam Board mike_duclos Building & Construction 7 06-24-2011 07:17 PM
Air cavity required behind spray foam roof insulation BigJimmy Building & Construction 9 06-08-2008 12:45 PM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 04:42 PM
Stone veneer over foam board. rfjm58 Building & Construction 6 04-10-2007 06:40 AM
