Adding A Chimney Chase To An Existing Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By sixeightten
Old 07-25-2016, 05:52 PM   #1
Rewards Points: 2
adding a chimney chase to an existing roof
I am getting ready to have a chimney chase installed in the middle of an existing roof to enclose an existing metal chimney pipe. My question is how should the installer go about securing it to the existing structure?
the chase will be approximately 8' tall by 4' wide by 3' wide and we can get winds 50 to 70 mph, so I am concerned about the wind loading and ensuring that the chase is secure.
appreciate any thoughts or suggestions.
jws13 is offline   Reply With Quote
Old 07-25-2016, 06:29 PM   #2
Framing Contractor
Rewards Points: 76
Re: adding a chimney chase to an existing roof
The corners of the chase should poke through the rof structure, and be tied into the framing below as much as possible.
Mingledtrash likes this.
sixeightten is offline   Reply With Quote
Old 07-25-2016, 07:52 PM   #3
Rewards Points: 1,036
you could also possibly use CST or MST straps at each corner and just cut a small slot to feed the strap through.
Mingledtrash is offline   Reply With Quote
Chimney repair - roof leaking slice4444 General DIY Discussions 32 04-27-2014 07:51 AM
Chimney leak on a flat roll-shingle roof qslim Roofing/Siding 24 02-08-2014 07:26 AM
Flintlastic SA over existing torch down roof? aribert Roofing/Siding 2 05-16-2012 08:32 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 11:37 PM
