Adding A Ceiling To A Stick Built Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By SteelGuitar
Old 04-09-2018, 11:34 AM   #1
Rewards Points: 6
Adding a Ceiling to a Stick Built Garage
Hello! First post here so go easy on me...
I've been searching the internet looking for an answer to a question about my garage. I'd like to add a ceiling to my detached garage with insulation (probably R-19) and drywall. The reason is I'd like to be able to work out there year-round. Here's a little detail on what I've got:
- Stick built construction, roof rafters are 2x4, 16" OC
- There are currently 3 - 2x6 collar ties that span the width of the garage (18')
- walls are 2x4 construction, 24" OC
- Garage dimensions are 20' deep, 18' wide
Can I add a ceiling to this without breaking the bank? Will 2x6" joists work if I tie them to the rafters and build trusses?
Thanks for your help!
SteelGuitar is offline   Reply With Quote
Old 04-09-2018, 12:03 PM   #2
retired framer
Rewards Points: 6,066
Re: Adding a Ceiling to a Stick Built Garage
I think yes if you don't plan on storage up there.
BTW those are rafter ties, Collar ties are in the top third of the roof.
The Following User Says Thank You to Nealtw For This Useful Post:
SteelGuitar (04-09-2018)
Old 04-09-2018, 12:09 PM   #3
Rewards Points: 6
Ah good deal, thanks for your response and clarification on the rafter ties.
So is there a trick to getting new joists up in place on an existing garage? Notch out the ends and lift them up at an angle to get them into position?
Yep, no storage, just insulation and drywall.
Old 04-09-2018, 12:20 PM   #4
retired framer
2 1/4 inches on each end would be about minimum bearing. You should be able to swing it in and stand it up.
Or rafter ties can be anywhere in the bottom third so you could go up a foot or so with shorter pieces giving you a higher sealing. Then you make the small sloped area thicker to allow for insulation and venting.
Old 04-09-2018, 12:42 PM   #5
Rewards Points: 6
Ah, that's awesome, thanks for the advice. So if I run into issues putting up the full length, I'll cut them down and move the ceiling up.
Nealtw likes this.
Moisture barrier for garage ceiling syogod Building & Construction 5 01-26-2017 04:54 PM
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 10:22 AM
Garage renovation/vaulted ceiling & removing "ceiling joists" brandonlaundry Building & Construction 7 02-20-2011 12:27 PM
garage ceiling moisture chezseans General DIY Discussions 4 02-08-2010 03:35 PM
adding on to an existing detached garage ebstein Building & Construction 4 09-24-2009 11:32 PM
