9.25" Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-04-2009, 08:41 AM   #1
Rewards Points: 736
9.25" joists
Is a 9.25" joist beam the same as a 2x10? I thought it was but just wanted to make sure
BlueBSH is offline   Reply With Quote
Old 12-04-2009, 08:45 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,492
Yes...
I bet it ain't 2" wide either..
Dimensional lumber is sized by what it was Cut too, not what it's planed too...
Old 12-04-2009, 09:21 AM   #3
Rewards Points: 736
Originally Posted by Bondo View Post
Yes...
yeah its like 1.8" wide but was just making sure my assumptions were correct
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 06:41 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 12:48 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 08:50 PM
