8x7 Garage Door Header - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-31-2014, 01:31 AM   #1
Rewards Points: 1,238
Not much info on the search engine.
Really easy -
Phoenix, AZ
NO snow load
2x4 construction
Garage door opening on gable end
One story garden shed
I know two 2x12s would do this trick, but it seems overkill. Realistically, would two 2x8s do the job on double jacks? Or would it be best for two 2x10s? I'm not buying engineered. Thanks
Daugela is offline   Reply With Quote
Old 10-31-2014, 10:57 AM   #2
Rewards Points: 1,910
see Table R502.5(1)
http://www.bradleyco.net/resources/5...n%20Charts.pdf
Old 10-31-2014, 12:00 PM   #3
concretemasonry's Avatar
Rewards Points: 2,716
Are you worried about strength or deflection? They are different.
Dick
concretemasonry is offline   Reply With Quote
Old 10-31-2014, 02:40 PM   #4
Dick
Deflection
Old 10-31-2014, 02:57 PM   #5
The chart is for a bearing exterior wall. How about a wall under the gable end? Non-bearing exterior - Trusses held on other walls? Does this same calculation apply?
Old 11-02-2014, 10:29 PM   #6
Rewards Points: 5,012
What type of door will you be installing.?
ron45 is offline   Reply With Quote
Old 11-02-2014, 10:36 PM   #7
Regular non-insulated metal garage door with garage door opener.
Old 11-03-2014, 03:05 PM   #8
Rewards Points: 1,668
Multiple variables, but one thing to consider is the amount of work you MIGHt save if you go double two bye twelve pushed up against the bottom of the to plate, e.g. No cripples to cut and nail in. And a double two bye twelve at eight foot seven and a half inches assuming double jacks is not all that much heavier than double two bye ten. Ron
ront02769 is online now   Reply With Quote
Adding subpanel to Garage jimmyfloyd Electrical 2 11-09-2012 10:22 AM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 11:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
