8x10 Vs 6x6 Bathroom Tile-- Any Difference? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 08:46 PM   #1
Rewards Points: 175
8x10 vs 6x6 Bathroom Tile-- Any Difference?
Do these sizes of tile require different adhesive? The 8x10 thinset mortar perhaps? Will regular mastic hold it? Any other advantages/disadvantages of one size over another or is it just a look thing?
smata67 is offline   Reply With Quote
Old 07-12-2009, 09:04 PM   #2
Rewards Points: 5,348
Thinset should be used in wet areas like tubs and showers. The trowel size will be larger for the 8x10 tile. The bag of thinset will guide you to the correct size. If the tile has a lugged back, the trowel notch will be larger then if it's flat.
Ron
Old 07-13-2009, 07:03 AM   #3
Rewards Points: 175
I forgot to mention these were wall tiles. Why have I been using the mastic type adhesive all these years? Is it because I had 4x4 tiles?
Old 07-13-2009, 03:38 PM   #4
Mastic can be used on drywall outside of the tub or shower and it will last a long time. Thinset is a better product when used wth cement board.
Many homeowners used greenboard in the wet areas as they thought it was appropriate and used mastic because it was easier.
Ron
Tile sizes in bathroom? trueform General DIY Discussions 37 07-01-2008 10:34 AM
12x12 tile on small bathroom walls???? trueform General DIY Discussions 4 06-23-2008 11:34 PM
marble tile in bathroom floor Arianeg Flooring 1 03-18-2008 03:07 PM
Bathroom Tile Shower Remodel MattCoops Remodeling 2 04-30-2007 05:48 PM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 07:03 PM
