600' Trench DIY? - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-09-2015, 02:19 PM   #31
Rewards Points: 8
Also, if you're laying conduit, you have 2 choices: You can put the pull line in as you assemble it or you can have the electricians blow it in with air. If you go with option b, putting the pipe together goes a lot faster but you have to put pull boxes in I would recommend no more than 300 ft apart. If you can get a helper, you can trench ahead, he puts the pipe in and when you finish trenching you can go back and start backfilling behind him. That won't work if you need an inspection on the trench obviously.
hokiesmokes is offline   Reply With Quote
What concrete to use on a trench? marty813 Concrete, Stone & Masonry 6 10-11-2013 09:24 PM
French Drain or some other idea for wet yard wnewman Landscaping & Lawn Care 10 07-26-2012 09:33 AM
Drain Tile Trench dnt Flooring 1 04-12-2011 04:11 PM
backfill & grass over a gravel trench ??? linboomer Landscaping & Lawn Care 4 05-09-2009 07:54 AM
opinions wanted on foundation trench sketch annie68164 Building & Construction 12 03-05-2009 12:38 PM
