4x6 Or 6x6??? POSTS - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 01:12 AM   #1
4x6 or 6x6??? POSTS
This shouldn't be to tough, but nobody i know knows the answer!!!
without spending $$$$$ on engineers
I have a 4x12 LVL 24' long with a post at one end, a post at 12' and the other end dies in a wall. It supports the upstairs living space with a low pitch roof (virtually no attic)...last year had 2' of snow with no problems. it's a funky ole house and i'm redoing the basement for living purposes. Right now it's holding up fine, probably built in the 60's by farmers, rednecks or hippys. I want to support the load with beams at the mentioned above places. I would like to use 4x6 post to keep the design straight. Will they work or should i up grade to 6x6. Thanks for your assistance people
ZDOG is offline   Reply With Quote
Old 08-10-2011, 08:10 AM   #2
Rewards Points: 5,348
You're leaving out a few details.
This support beam was a replacement for the original, as well as the number and location of the supports.
What was the original set up?
Why was it changed?
Normally, you would see 2 supports in that set up. One every 8 feet, not 12 feet.
How big are the footings for the support that is currently there?
Is this a one or two story house?
Post some photos.
Ron
B. Franklin 1759
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 08:03 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 03:55 PM
help settling porch posts - a dilemma. wombosi Carpentry 9 10-10-2008 01:01 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
Cracks in pressure treated posts (4x4s, 6x6s) Deck Building & Construction 8 05-15-2008 11:57 PM
