4-season Room Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-18-2012, 06:31 PM   #1
4-season room addition
I'm contemplating adding a 4-season room approx 16 x 28 with studio roof. Is better / more economical / just as satisfactory to have someone build it from scratch or to buy a pre-fab aluminum kit and have that installed professionally? Thanks!
Barb4417 is offline   Reply With Quote
Old 05-18-2012, 07:05 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,422
Contemplate hiring an architect to evaluate your house and lot in it's entirety for suitability, structural and mechanical considerations... as well as the aesthetics.
Is better / more economical / just as satisfactory...
...is having what you do eventually spend your money on meet all of your design needs as well as the codes and regs so it can stay up once built
hth
Old 05-21-2012, 03:15 PM   #3
Build one from scratch. Have it designed to match the architecture of your home. It will last longer and offer more value than the prefab ones. The prefab ones I've seen over the years always end up with roof problems, which are nearly impossible to fix long term. Good luck with your project, Mike www.mikemedford.com
mikemedford is offline   Reply With Quote
bonus room addition electrical wires notch studs or re-wire Hoppy269 Building & Construction 7 06-10-2011 02:58 PM
room addition stasie120 Building & Construction 6 06-04-2011 08:31 PM
Well Room (Cold Room) Issue--Advice Needed TomPgh Building & Construction 11 01-03-2011 07:31 PM
3 season room roof leaks rod altman Carpentry 7 12-22-2010 10:56 AM
Cold Room mikelbeck HVAC 14 01-16-2009 09:21 PM
