4 By 6 Structural Load Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2010, 12:45 PM   #1
4 by 6 Structural Load Question
maximum load for a 4 by 6 post
cesar cortes is offline   Reply With Quote
Old 06-16-2010, 01:06 PM   #2
Under what conditions/placement ?
Old 06-16-2010, 01:56 PM   #3
See the first figure
http://www.efunda.com/formulae/solid...ns/columns.cfm
The Area Moment of Inertia = I = (b(h^3))/12 = 5.5(3.5^3)/12 = 19.7 inches^4
E is typically 0.8 to 2.2 MPSI
For L = 6' and E = 800,000 my spreadsheet tells me 30,000 pounds.
To quote Edwin Starr, "Good Gawd, y'all!"
Old 06-16-2010, 02:08 PM   #4
jlhaslip's Avatar
Rewards Points: 708
wood type?
wet condtions?
4 x 6 or 3.5 x 5.5?
grade of wood?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 06-16-2010, 06:37 PM   #5
Civil Engineer
Rewards Points: 5,246
A post is a type of column. The allowable load on a column is usually controlled by buckling, unless the column is very short. Maximum allowable column loading when controlled by buckling is a function of the unbraced length, the eccentricity of the load, the slenderness ratio of the column, the material properties of the column, and the required safety factor. You cannot determine the allowable load on a column until you have established each of these factors.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Willie T (06-17-2010)
Old 06-17-2010, 08:55 AM   #6
You could make a 1/10th scale model. Using .35", .55" and 7.2" the column should collapse at 'around' 300#.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 05:48 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
