3/8 Rib Lath Installation To Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-13-2010, 07:48 PM   #1
3/8 Rib Lath installation to joists
Hello,
I am installing 3/8 Rib Lath on a ceiling in my house and have the ASTM 1063 information but am missing some details to ensure I get this correct.
Can someone help please?
Using galvanized fasteners...
Here is the section from the ASTM....
"7.10.2.3 Expanded 3⁄8 in. (9.5 mm) rib lath shall be attached
to horizontal and vertical wood framing members with nails or
staples to provide not less than 1 3⁄4-in. (44.5-mm) penetration
into horizontal wood framing members, and 3⁄4-in. (19.1-mm)
penetration into vertical wood framing members."
I know the rib has to be in contact with the joist.
If I nail through the rib it will distort the rib when the nail head enters the rib. How can you nail the 3/8 Rib Lath to the joists?
If I go with the staple.... There is mention of using a staple with 3/4 crown for the walls but no specifics for the ceiling other than penetrating 1 3/4 inch.
Since it is 3/8" wide rib can I use a 3/8 wide staple that is 2" long, it would need to be 2" long if I straddle the rib because the rib is ~1/4 tall and there needs to be 1 3/4 penetration.
I have been searching the internet for a few days and have 4 or 5 hours researching into this and haven't found any definitive instruction on this. I am hoping there is someone here who has experience with this.
Thanks,
Jeffrey
jefsboys is offline   Reply With Quote
Proper installation of sister joists carbon Building & Construction 7 10-02-2010 09:17 PM
self furring metal lath installation - help wombosi Building & Construction 4 07-20-2010 06:37 PM
Considering replacing playwood subfloor, many questions. gante Flooring 3 04-12-2010 11:39 PM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 05:43 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 08:43 PM
