3/4" Osb Or 3/4" Plywood For New Sub Floor? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-17-2011, 07:57 PM   #16
kwikfishron's Avatar
Rewards Points: 172
Haven't a clue.
As long as the Tile Guy is happy.
kwikfishron is offline   Reply With Quote
Old 03-17-2011, 08:05 PM   #17
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I can assure you they don't use Advantech to keep me happy. They also don't usually shop at the big box. These are quality-minded builders that have had too many issues with a lot of the big box materials. I think they are convinced a better grade of material is available from a real lumber yard.
XXX
Old 03-17-2011, 09:03 PM   #18
Rewards Points: 172
Real lumber yards is all I know the closest Box to me is a hr.+ away. I’m all for quality materials as I’m sure Advantech is but have never seen that product used here. The new stuff usually has been out East for a few years before West gets it, and that’s just fine with me, let you guys be the test. You’ll never here me pitch OSB but yet all “real lumber yards” stock it. And to say if you don’t build with anything but Advantech means your not “quality-minded” is …….. America was built with CDX. Can’t wait for the 15 year review on the “Zip System”.
Old 03-17-2011, 10:45 PM   #19
thanks for all the help, sounds like I have solid info to work from, now! just need to watch the weather and make a decision from that of how fast I can get it in the dry to decide which material I will use. THANKS!
treerat is offline   Reply With Quote
Old 03-17-2011, 11:12 PM   #20
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I looked high and low in this thread and I don' see where anyone has said that.
So far the Advantech recommendation is the consensus - that's all.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
tcleve4911 (03-17-2011)
Old 03-18-2011, 07:31 PM   #21
Rewards Points: 150
Hold on Treerat.....just consider,you probably have already, but what about a concrete floor if your close to grade? If your planning on a ceramic tile floor, it may be the way to go.All depends how far from the dirt you are, and how cold of climate your in, and your ability to get a slick finish. Just a thought.
bernieb is offline   Reply With Quote
Old 03-18-2011, 10:41 PM   #22
Rewards Points: 426
I've seen some Advantech take quite a beating with spring rains with virtually
no effect .
http://www.advantechperforms.com/get...t-locator.aspx
http://www.advantechperforms.com/dar...mparisons.aspx
High Gear is offline   Reply With Quote
Old 03-18-2011, 10:53 PM   #23
liscenced electrician
Rewards Points: 540
you could always paint your plywood before installing it. Wouldn't be that hard if its just a bathroom
jimmy21 is offline   Reply With Quote
Floor is out 3/4" zetti1102 Flooring 11 09-26-2010 10:31 AM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 02:08 PM
Movement in bathroom floor rob_di_mostly_y Kitchen & Bath Remodeling 2 07-24-2009 04:37 PM
floor leveling, plywood subfloor in a bathroom bloom42 Flooring 2 02-05-2009 07:55 PM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 11:32 AM
