2x4 Joist Options - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 06-01-2017, 12:45 AM   #16
Rewards Points: 14
Re: 2x4 Joist Options
I might have found something! Bailey Metal Products make lightweight steel framing wall studs and floor joists. I read through their load tables and found one of their 2x6 joists can match my span, spacing, load and deflection targets. I cross matched one of their 2x4 studs (albiet thicker gauage) that has the same or greater properties than the 2x6 and only weighs ~19lbs (comparable to spf). Would that work as a direct replacement?
BMP Load Table
mmind is offline   Reply With Quote
Repair of Damaged Ceiling Joist with a Split/Check in it? Lovegasoline Building & Construction 19 06-13-2016 05:47 PM
Repair/replace sill plate and joist ends heybales Building & Construction 5 02-16-2013 11:33 PM
notched out joist ? problem ? cvcman Building & Construction 13 05-24-2012 09:21 PM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 02:30 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
