2x10 Joist Working Load 14' Span - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-18-2010, 11:19 AM   #1
Mike K
Rewards Points: 97
2x10 Joist working load 14' span
I would like to hang a 600 lb motorcycle in my garage from two 1500lb boat trailer winch's. One winch will be bolted to the 10" steel beam running the width of garage and length of the home. The other winch would have to bolt to the ceiling with 2x10 joists ,16" centers, 14' span, but only 4' away from the 10" steel beam.
My plan is to lag bolt a 6" steel beam under the joists for the winch to bolt to. My question is how many joists do I need to span to carry the 600lb motorcycle safely?
rebar is offline   Reply With Quote
Old 08-18-2010, 11:59 AM   #2
Rewards Points: 5,348
This sounds like a plan of potential dire consequences. That much weight should be on the ground. I put the 700 lb bike in the shed as there's no room in my 2 car garage.
Ron
Old 08-18-2010, 01:27 PM   #3
Rewards Points: 736
That's definatly a lot of dead weight on 2x10"s at 14' heck I would never suppend something that heavy, but that is me... if you where really set on doing it, I'd for safety have a steel I beam with brackets looped around it and welded in place
BlueBSH is offline   Reply With Quote
Old 08-18-2010, 01:41 PM   #4
Registered User
Rewards Points: 526
To use the existing beam that is rated for the load already on it and probably not much more would be foolish. I doubt the builder put in an extra strong one as they cost more. Adding a point load to joists that are rated for a distributed load is another problem. To try and figure the withdrawal strength of the lag bolts and the attachment would require a Structural Engineer to accept the liability involved. Have you looked into the lifts available? If for storage, could you build a removable ramp onto a raised platform?
Be safe, Gary
Old 08-18-2010, 09:48 PM   #5
Mike K
Rewards Points: 97
I should have added before that this project is intended to replace a bike lift. My knees have had it and I have a few bikes I maintain. And the space in my garage is limited. A bike lift is over 7" tall when lowered. That's to tall to even park a bike on it etc etc.
The 1970 10x6x1/2 steel I beam is plenty over engineered . I had a Cal King water bed above it years ago with no problems.
The additional I beam lag bolted to the 2x10's is another situation. But Im positive 4 adults equaling more than 600 lbs standing directly above the hang spot wouldn't be a issue. Unless both situations.. Bike hung with 4 teenages jumping above, occur at the same time. Wont ever happen..
If I locate centerlines of the 2x10's accurately by poking around with a small drill bit. I know a 6x4x1/2" I beam lag bolted to lets say.. Seven 2x10's, extending all the way and anchored to the concrete foundation would hold 400 lbs easy. The I beam might weigh more.
Old 08-19-2010, 01:52 PM   #6
Newbie Bill
Rewards Points: 534
So is hanging the bike from the roof for storage purposes or to work on the bikes at a more acceptable level? If it is the latter, it would be cheaper and safer to get yourself a higher motorcycle lift.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
How to repair floor joist when sistering is not an option jmagee3d General DIY Discussions 2 06-05-2009 02:33 PM
2x12 joist span phillybr Building & Construction 3 03-31-2009 09:38 AM
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 10:16 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
