2 Story Home Load Bearing Walls? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 02:43 PM   #1
Smile
2 Story home load bearing walls?
We are moving into a home that needs major renovation mostly cosmetic just a lot of it. I want to cut an opening into a wall in the dinning room. It is not a exterior wall but it is on the lower level. How do I determine if it is load bearing and if I can cut into it?
TRBORGMEYER is offline   Reply With Quote
Old 03-26-2013, 02:58 PM   #2
Rewards Points: 18,382
You can get engineer or builder to come take a look at it.
Not something you want to trust strangers that have never even see the house decide.
Remove the wrong wall and it will effect the rest of the house.
Old 03-26-2013, 05:49 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
joe is spot on ..... unless you plan on doing all the bracing, cutting and framing yourself it is best to have someone knowledge to do the work. depending on where you are located it probably will require a building permit
as joe said making a mistake at removing a load bearing wall can lead to a lot more issues
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-26-2013, 07:34 PM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,512
Originally Posted by TRBORGMEYER View Post
How do I determine if it is load bearing...
Go down to the basement, find the support columns, beams and floor joists.
Calculate which of these this interior wall "stacks" over top of.
If the wall is right over top of the beam and columns...
...and if I can cut into it?
Not "if"... how.
Getting that right will take a while to be sure all the bases are covered
and how expensive it will be to complete.
Tags
load bearing wall
Load bearing wall removal question... Huggins90 Building & Construction 17 01-21-2013 11:07 AM
Identifying load bearing walls in 2 story home. . . Alan Carpentry 7 02-20-2011 01:23 PM
load bearing walls rvesci General DIY Discussions 4 12-28-2010 10:51 PM
interior load bearing walls with a heated slab? forresth Building & Construction 4 03-15-2010 01:21 PM
load bearing walls unicorn23 Building & Construction 12 07-04-2009 08:54 AM
