I'm framing a new door opening in my bathroom. I'm trying to work around a vent pipe that is restricting the size of the door. Can I use a 1x4 for king stud on one side? What about the trimmer on the non-hinge side?
Yep, except the picture shows a stressed gable truss on the gable, not a studded stressed gable truss for the sheathing fastening requirements. Looks a lot like "Advanced Framing" which uses Simpson Header Hangers: http://www.strongtie.com/products/connectors/HH.asp
So just based on that, I would say NO, a 1x4 can not be used as a king stud.
According to wisegeek, some building codes require a king stud. Their purpose seems to be to help prevent latteral movement of the other framing members. http://www.wisegeek.com/what-is-a-king-stud.htm
So if code doesn't require a king stud, you could rely on only the jack stud to transmit the load of studs being removed for the door and omit the king stud all together. But the construction is considered to be less sound.
The door is in a non-load-bearing wall. Thanks to everyone's input, I was able to find this IRC reference:
IRC 2000 and 2003, Section R602.7.2
Nonbearing walls. Load-bearing headers are not required in interior or exterior nonbearing walls. A single, flat 2-inch-by-4-inch (51 mm by 102 mm) member may be used as a header in interior or exterior nonbearing walls for openings up to 8 feet (2438 mm) in width if the vertical distance to the parallel nailing surface above is not more than 24 inches (610 mm). For such nonbearing headers, no cripples or blocking is required above the header.
I'm not sure who drew the picture. I linked to it on a government Website. At any rate, Chief Architect's Home Designer Pro is a pretty good tool. The old versions are pretty cheap now. PowerPoint will also work in a pinch.
Yeah, I put headers over everything
A gable end with proper support I might use 2x4's on edge
---I did this in (3) places on small windows when there was either a 2x6 header within 2' above it or a double top plate
But usually a 2x6 header is a min for me
Just not worth it to save the $10-20 cost of the header
Correct. The max above the header in the picture is limited to 2' because the sheathing needs nailing that max distance before adding cripples for closer nailing.
Related Threads
DIY Home Improvement Forum
3.1M posts
320.1K members
Since 2003
