1960's Slab House - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-28-2010, 05:25 PM   #1
KCB
1960's slab house
Hi all , central Kentucky area .
Ive started a 16x30 room addition and have dug the footers
at 28" (24" is frost line) . The problem ive encountered is the original footer is at 18" so im approximately 10"s lower than the original footer.
What is a work around tie in to join these 2 footers?
KCB is offline   Reply With Quote
Old 06-28-2010, 10:06 PM   #2
Civil Engineer
Rewards Points: 5,246
Why do you want to tie the two footers together? I am guessing you did not get a permit, maybe you don't need one, so this doesn't sound like a code issue. As long as you are on adequate soil, and the footers are properly built, you gain absolutely nothing by tieing the two foundations together. As long as the original foundation is working, you should be able to build the two foundations independently.
Old 06-29-2010, 05:37 AM   #3
KCB
all the literature ive studied suggested it , and yes i have all the needed permits .
Old 06-29-2010, 04:48 PM   #4
Rewards Points: 3,602
if you want, drill into the existing vertical end & epoxy deformed steel into it extending 18" into the new conc,,, i'd probably use 4 if it were ours.
Old 06-29-2010, 05:28 PM   #5
Civil Engineer
The footers are at two different levels, so in order to tie the two footers together would required Z shaped bars. I cannot see what possible structural value that would add. As for the documents you read that recommended this technique, they may have been referring to two footers at the same level, or possibly to an initial pour of a multilevel footing, I don't believe they were referring to retrofitting bars into two distinct footers that are on different planes.
Old 06-30-2010, 05:02 AM   #6
KCB
Ive not read any documents concerning this problem.Ive read plenty concerning footers of the same depth . Thats why i posted here for solutions .There may or may not be an issue here but my thoughts of joining 2 footers is to "prevent/minimize" over time' sagging of 2 different structures,10/20 years down the road.Or at least settle together with minimal movement .
Old 07-03-2010, 07:11 AM   #7
KCB
That was our first thought "and is what we ended up doing using 2 rods" .
The Code inspector said we didnt have to join the footers .But replied "the more support the better"
Weird wiring in house fdmillion Electrical 13 06-14-2013 06:49 PM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
Heating Unit in the Attic Bad Idea? Part of House on Slab cloves HVAC 3 08-18-2009 11:37 AM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 10:01 PM
