1/4 Inch Fanfold - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2009, 10:09 AM   #1
1/4 inch fanfold
I will begin siding my house with vinyl soon and would like some opinions on whether to lay down 1/4 inch fanfold or not. Only reason I would do it is for the extra insulation but from what I gather the r-value of the stuff is only 1 or 1.5 . I will be wrapping house with Tyvek. The exterior area of the house is abt 2000 sq feet.
Is this a waste of money?
Thanks in advance
SAGENT is offline   Reply With Quote
Old 06-16-2009, 01:39 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Fanfold has a very limited R value. It is mostly used as leveling board to flatten the surface before you hang your new siding, such as if you are siding over top of old beveled wood siding. House wrap is a good idea, but if you are looking for R value, then fanfold isn't the stuff to use.
Old 06-16-2009, 02:06 PM   #3
Not so new
12penny's Avatar
Rewards Points: 524
sagent....here in eastern pa. 3/8 x 4' x 50' fanfold is an R1.5 and sells for about $36, and if I shopped around better prices could probably be had. For 2000 sf that would run about $360. IMHO, any chance you have to increase the r value in your home, you should do so. Especially if it only costs $360. Not sure but there may also be a federal tax credit for doing so.
12penny is offline   Reply With Quote
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
1 1/2 inch zone valve - can't find BOUTYM HVAC 2 11-20-2008 10:03 AM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 11:19 AM
new 41/4 inch tile does not match old 41/4 inch tile sweet123 Flooring 2 12-27-2007 08:53 PM
