Zinsco Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 09:39 PM   #16
I=E/R
a7ecorsair's Avatar
Originally Posted by Proby View Post
like I mentioned earlier and pull the meter himself or just tape up the feeders when changing the panel, this way you aren't at the mercy of the power company and their schedule.
I just have to ask, curiosity has me wondering what you mean.
Are you saying that sometimes you pull the feeds from the main breaker and tape them up really well without pulling the meter?
a7ecorsair is offline   Reply With Quote
Old 08-04-2010, 09:42 PM   #17
A DIY person pulling a meter ??
I won't even try that
Arc flash only needs to happen once to spoil your life
Old 08-04-2010, 09:46 PM   #18
Electrician
Proby's Avatar
Some meters are locked and I only have a couple of barrel lock keys, won't open them all.
When that happens I cut off the exposed copper from the feeder cables and give it a wrap of rubber tape and then Super 88. If it's enough to permanently cover splitbolt connectors, it's fine for a quick panel change-out.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-04-2010, 09:46 PM   #19
Electrician
Proby's Avatar
No one mentioned a DIYer pulling a meter. Quite the opposite actually.
If you kill the main disconnect, there are no arcs. It's still not a safe practice for someone without experience.
Old 08-05-2010, 09:01 AM   #20
Electrical Contractor
jbfan's Avatar
Rewards Points: 966
Sounds like the first quote included permits, while the second quote did not.
Since you rent rooms out(in my state) any electrical work must be performed by a licensed electrician.
$700 hundred just to change the panel, without an outside disconnect is low.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 08-10-2010, 04:34 PM   #21
Bergen county.
Me, too. It's not quite as depressing as those other places.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Zinsco Sub panel DonKrueger Electrical 0 03-22-2010 12:46 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 03:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
