DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Yeah. I don't think that's good. (https://www.diychatroom.com/f18/yeah-i-dont-think-thats-good-72236/)
jannington 05-27-2010 07:48 PM
I'm gonna keep this pretty short and direct... There's an outlet in our basement room which, when in the process of plugging something into it, causes the power to go off in the entire household. It doesn't trip a circuit, doesn't make any terrifying arcs or put out any heat that I can notice but it's still pretty concerning. One thing that's notable though is it's somewhat difficult to plug something into it and from the moment you start pushing it in to the point where it's fully in is when the power in the whole house is killed.
Like any reliable scientific observation it's completely repeatable and I'm wondering how this is even possible (But, I know nothing about electrical engineering so this really isn't too surprising).
Any help would be seriously appreciated as I have no idea if this could be a minor screw up or something that could seriously compromise the safety of this house.
AllanJ 05-27-2010 08:29 PM
Most likely there are bare wires almost touching inside that do touch when the receptacle is wiggled as you plug something in.
Jim Port 05-27-2010 09:01 PM
Is this tripping the main breaker when you attempt to plug something in. What do you mean it kills all the power in the house?
joed 05-27-2010 09:17 PM
Stop plugging stuff into that receptacle.
Unless your entire house is on one circuit, what you describe is not possible unless the main breaker is tripping.
Replace the receptacle.
AllanJ 05-27-2010 09:17 PM
I have read accounts of short circuits that should trip a branch circuit breaker but trip the main breaker instead. I don't fully understand why this happens but there is a time delay between when the short occurs and when the breaker trips. Hopefully something trips before wires in the wall or anywhere heat up and become a fire hazard. Maybe the main breaker just acts faster.
jannington 05-28-2010 01:59 AM
Yeah I figured the responses would be something like this as I don't really understand what could be causing it...
As far as I know, no breakers inside of the house are tripping (as I've never had to reset one after dealing with this outlet) but the entire household experiences a complete power drop when I plug or unplug something in, usually no more than a second. There's really no simpler way to describe the chain of events.
Yep probably a good idea.
That's what I would assume as well but it's not like I'm making this up.
Also a good idea.
However, curiosity really has the best of me and I'd like to see if anyone has theories as to why or how this can happen... kind of like the ones AllanJ mentioned except like I said before no breaker in this house is tripped (unless I have a misconception as to how breakers usually work - I assume that they can only trip to interrupt the circuit?)
Thanks for the input so far, guys.
Red Squirrel 05-28-2010 02:22 AM
I'm thinking there is a problem of some sort causing it to short out when you plug something, but with that, the breaker it's on is faulty, so it is not tripping like it should, so the main trips instead. You probably get a very solid short connection when it shorts out, so there's less of a fireworks show. That's my guess anyway.
As for the problem causing the short in first place, I'd guess the receptacle itself is damaged inside and plugging something in causes the hot to touch neutral or ground. First I would replace it, and see if that fixes the problem, if it does, then try to overload the circuit by plugging lot of stuff into it to ensure the breaker trips like it should. If it's a 15 amp breaker then try to draw 20 amps. Don't do this for too long as if it does not trip, then it becomes a hazard. Now I'm not sure how long it should take for a breaker to trip, but I'm sure you can find info on Google based on your breaker brand. Maybe there's a better way to test this though. See what the others have to say.
Oh and is it a stab lok by any chance?
bob22 05-28-2010 07:55 AM
OP said:
"As far as I know, no breakers inside of the house are tripping (as I've never had to reset one after dealing with this outlet) but the entire household experiences a complete power drop when I plug or unplug something in, usually no more than a second. There's really no simpler way to describe the chain of events."
Do you mean that the lights dim in the rest of the house momentarily or the lights go out? What are you plugging into this outlet?
oh'mike 05-28-2010 08:01 AM
Have you even put a tester on this? If the main is popping--you might have
a 220 short---
No neutral--just two 110 powers from different legs.
Possible--You need to figure this one out with a tester.
There are a lot of electricians in this world---You may wish to call one.
Trouble shooting this problem should not be to difficult.--Mike---
brric 05-28-2010 08:15 AM
Where in the OP does it state that the mmain or any other breaker is tripping?
joed 05-28-2010 08:35 AM
This is different then what I thought was happening. Now it is only power blink. I thought the power in the entire house giong off.
I still can't explain it.
jannington 05-29-2010 06:02 PM
Red Squirrel I'm gonna be replacing this outlet tomorrow most likely so I'll see if it is or not (I have a GFCI outlet laying around). You have an interesting theory but I hope nothing is wrong with the breaker as that's more of a problem than I would want.
Originally Posted by bob22 (Post 448016)
OP said:
"... but the entire household experiences a complete power drop when I plug or unplug something in, usually no more than a second. ... "
A complete drop. No dimming, just a momentary power outage in the whole house.
And in my experience thus far anything will cause the outlet to do this. I've plugged in lamps, a fan, and a vacuum cleaner.
Yoyizit 05-29-2010 09:19 PM
Measure the 240vac and the 120vac on each side of the neutral at the load center while you plug or unplug something into your troublesome outlet. You can access these voltages at an unused elec. dryer outlet without removing the CB panel.
If the 240vac is weird you need to call PoCo.
If not, measure the panel voltages downstream of this point while you plug or unplug something into your troublesome outlet
This is about as odd as it gets. For sure, this thread will be teaching some lesson.
chrisn 05-30-2010 04:01 AM
a 220 short---
There are a lot of electricians in this world---You may wish to call one.:thumbsup:
I agree,something bad AND dangerous is happening here.
Red Squirrel 05-30-2010 03:33 PM
Ok so when you unplug the item, does the power come back?! I just automatically assumed it was tripping the main. If it's not, then this is indeed a even stranger problem.
I remember once as a little kid I was playing with 4 light sockets (yes, 120v ones lol) and connecting them together randomly, and then plugging it into the wall. I knew how series and paralel worked, so I was trying more interesting stuff. I had them connected some weird way I don't recall, but if I would unscrew one of the bulbs, the 3 others would go on. If I recall, one was dim, the other two were normal. When I screwed the other bulb back in, the 3 lights would go off, slowly (well maybe 1-2 secs, but not instant) and the one bulb would go on. I don't recall if this is exactly what happened, but it was something to that extent. Very strange. I'm sure there's a better explanation for it. Maybe this is what is going on with that outlet?
If you plugged something in, and a non working outlet or lights started to work, then I'd say it's a bad neutral somewhere, but since everything goes off when you plug something in... then yeah, very interesting lol.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
