Xmas Inflatable - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2015, 02:03 PM   #1
Rewards Points: 109
xmas inflatable
I had the adapter on my xmas inflatable go bad. It is 12v 1.5 amp. The only one I have is 12v .5 amp It runs the fan and inflates . Will the lower amperage be a problem?
hitmehhh is offline   Reply With Quote
Old 12-21-2015, 02:15 PM   #2
Rewards Points: 602
The labels on those adapters are telling you how much current it can safely produce without overheating, etc. Can they produce more? Sure. Will they get too hot and melt? Probably.
The real question is how much current does the fan actually use? I suspect the fan uses less than 1.5A but the manufacturer included a 1.5A adapter because they wanted some headroom for startup and/or that is what they could get cheaply. If the fan draws 1.4A, then you'll certainly toast the 0.5A adapter. If the fan draws 0.6A, then you might be OK. Is there a label on the fan?
jreagan is offline   Reply With Quote
Old 12-21-2015, 02:16 PM   #3
dmxtothemax's Avatar
Rewards Points: 7,854
Yes !
It will be a problem.
You are overloading.
Your .5A supply.
It will burn out !
Get the correct supply.
dmxtothemax is offline   Reply With Quote
Fuse keeps blowing in xmas lights Mstrlucky74 Electrical 16 12-03-2015 08:13 PM
Small inflatable pool on deck....? french_guy General DIY Discussions 4 06-19-2014 06:12 PM
Xmas light string problem Ronnie1a Electrical 3 11-12-2011 06:53 PM
Inflatable pool safe on roof deck? bluejay1 Roofing/Siding 4 05-26-2011 01:22 PM
