Would Adding An Outlet Destroy Grandfathering? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-17-2015, 06:18 AM   #31
A "Handy Husband"
rjniles's Avatar
Rewards Points: 604
Originally Posted by Toller View Post
I don't know what jiggered means, but if it has to do with an inability to read, then yeah.
Never asked anything remotely like "would adding an outlet destroy grandfathering".
Maybe you need to read the title of this post. And I believe you wrote it.
My electrical answers are based on 2014 NEC, you may have local amendments.
The Following 2 Users Say Thank You to rjniles For This Useful Post:
123pugsy (09-17-2015), 47_47 (09-17-2015)
Old 09-17-2015, 07:02 AM   #32
Rewards Points: 1,832
A reputable company designed it that way.
It works adequately and does no harm. (as long as I avoid stepping in the sewage sump while it is running, I don't see how it could do any harm)
You would spend $1,000 to replace it? Yeah, that is absolutely amazing.
But it is great that you know more about pump design than Liberty.
Oh, Im sure they did. But riddle me this: Why do all metal frame appliances like refrigerators and washer require a 3 prong plug no matter how reputable they are?
Jump-start is offline   Reply With Quote
Old 09-17-2015, 09:18 AM   #33
Rewards Points: 2,800
"I'll be jiggered!"
I am mighty surprised!
also, I'll be damned!
Recommended viewing: "Little Lord Fauntleroy" starring Alec Guinness and Rick Schroder. (said several times)
Generally, replacing a defective component with a new component of like kind will not destroy grandfathering. Also, you are usually allowed to replace an existing regular receptacle or breaker with a ground fault circuit interrupter model. Adding a ground wire (equipment grounding conductor) whether within a newly strung replacement cable or as a separately run conductor usually will not destroy grandfathering.
Substantial although somewhat imperfect protection against electrocution is provided when the pump is hooked up using metal pipe and both the pipe and the pump frame are grounded using appropriate equipment grounding conductors.
Near perfect protection against electrocution is provided by GFCIs with or without grounding.
Nowadays metal framed equipment needs an EGC (provided via the grounded plug and associated/appropriate wiring) so that, in the event of a malfunction resulting in a fault to the frame, any fault current returns to the panel ground in a fashion that the voltage difference between the frame and any other somewhat grounded object such as a wet floor will usually be small enough to not result in electrocution. Also so that in the event of substantial fault current, which might essentially be a short circuit, the breaker will trip.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
The Following User Says Thank You to AllanJ For This Useful Post:
InPhase277 (09-17-2015)
Old 09-17-2015, 10:39 AM   #34
Licensed electrician
Rewards Points: 3,608
Nope, just had the idea today. Do a search if you have nothing better to do.
But thanks for taking the time to respond; too bad you didn't even try to answer the question.
Seems funny that someone also named Toller posted almost the same question on /19.
I guess you didn't like those answers?
Inphase277, thanks for finding the nonexistent thread.
Old 09-17-2015, 11:11 AM   #35
Rewards Points: 1,052
Originally Posted by Bob Sanders View Post
I'm not sure what the problem is here. You can add an alarm anywhere. Do a run of low voltage wire for the sensor, or use a wireless sensor/alarm. Why mess with line voltage, grandfathering, and code when you don't really have to?
I checked with the manufacturer. They say adding 100' of 22awg is fine.
Thank you so much for the advice!
Toller is offline   Reply With Quote
Old 09-17-2015, 11:14 AM   #36
Originally Posted by Speedy Petey View Post
Are you really this much of an a$$hole, or do you enjoy being a jerk to those trying to help you?
A couple people tried to help me, and I thanked them.
Several others just thought it would be fun to see if they could get me to replace a perfectly good pump. I'm outa here.
http://www.cbs.state.or.us/bcd/notic...30_OESC_pr.pdf
There are many others that also have the exemption.
Old 09-17-2015, 11:16 AM   #37
Obviously I mean other than this post. Damned, you are a jerk.
Old 09-17-2015, 12:03 PM   #38
A "Handy Husband"
rjniles's Avatar
Rewards Points: 604
You seem to be the only one showing his a$$. Have a good day.
The Following 3 Users Say Thank You to rjniles For This Useful Post:
123pugsy (09-17-2015), Jim Port (09-17-2015), Speedy Petey (09-17-2015)
Old 09-17-2015, 03:54 PM   #39
Rewards Points: 332
Man, this was interesting to read!
The whole purpose of these forums is to learn. Some people just don't want to learn and don't appreciate those who try to teach.
sgip2000 is offline   Reply With Quote
The Following 4 Users Say Thank You to sgip2000 For This Useful Post:
123pugsy (09-17-2015), InPhase277 (09-17-2015), Jim Port (09-17-2015), Speedy Petey (09-18-2015)
Old 09-17-2015, 11:19 PM   #40
Rewards Points: 1,428
Woah what just happened here
poiihy is offline   Reply With Quote
adding an outlet gt1935 Electrical 6 08-26-2015 10:27 AM
Adding an outlet to a bit of a mess... mikeyp78 Electrical 5 06-27-2014 02:11 PM
Adding new receptacles/ outlet federer Electrical 19 01-24-2013 03:14 PM
Adding an outlet on a 240V circuit? Kjunk Electrical 6 05-31-2008 09:27 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
