Workshop Sub Panel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 10:53 AM   #16
Rewards Points: 89
Thanks to all for there opinions on this. K buz thank you for your professional opinion also. I believe you are probably correct in that I am opening a can of worms by taking this route. I have been bouncing back and forth in my mind about which route to take, subpanel vs double lug meter and I think the smartest and safest approach would be the subpanel. It prevents me from overloading my service line from the transformer. I just really would like to have more than 100 amp service to the shop. Can anyone tell me if my homeline panel can support the 125 amp braker I found online that supposedly fits it? I can then run 2/0 al wire. Thanks.
hartkem is offline   Reply With Quote
Old 07-03-2013, 04:34 PM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Think about it this way...you are only one person, unless you have other people in there with you, you will only be able to use one maybe two machines. I highly doubt you will pull 100A much less over that.
Old 07-03-2013, 05:41 PM   #18
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 1,852
Maybe a grow house???? They are using LED grow lights now out here in Colorado... heat is still an issue in winter eating electrical.
MTN REMODEL LLC is online now   Reply With Quote
Old 07-03-2013, 07:43 PM   #19
Rewards Points: 89
No grow house but I will have ac and a lot of equipment. 100 amp will do but not much extra to spare
The Following User Says Thank You to hartkem For This Useful Post:
MTN REMODEL LLC (07-03-2013)
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Main Service Panel to 2 breaker panels - I can imagine you all rolling your eyes kalus Electrical 22 03-23-2012 02:09 AM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 08:00 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
