;;wiring A Well Pump To The Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 11:32 AM   #1
;;wiring a well pump to the breaker
I have a 12/2, wire for 220. I understand the black and white wires connect to each of the two breakers. Does it matter which one goes to the top breaker and which one goes to the bottom breaker/?
silvertop is offline   Reply With Quote
Old 08-04-2010, 11:37 AM   #2
Electrician
Proby's Avatar
It should be one breaker with 2 poles, that is very important. Two single breakers will not be a legal installation, even if you have a handle tie across them.
It does not matter what wire goes on what pole of the breaker, you are going to tape the white wire black anyway.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
The Following User Says Thank You to Proby For This Useful Post:
silvertop (08-04-2010)
Old 08-04-2010, 11:46 AM   #3
Thank you ever so much.
Appreciate the help. The breaker is a 2 pole just to make you feel better.
Goodman Heat Pump 2 Thermostat Wiring RanLoot Electrical 1 05-09-2010 07:20 AM
Heat Pump Low Voltage Wiring bobolink2000 HVAC 10 05-01-2010 09:50 AM
well pump keeps triping breaker ajmacd845 Plumbing 6 04-26-2010 10:26 AM
Thermostat Heat Pump Wiring difficulties akg4y HVAC 8 04-15-2010 05:16 AM
Heat Pump compressor trips circuit breaker joejean HVAC 3 08-28-2006 12:15 PM
