Wiring Up Air Handler With 15kw Heat Kit. HELP - Electrical - DIY Chatroom Home Improvement Forum
Old 06-23-2015, 03:51 PM   #1
Rewards Points: 16
Wiring up air handler with 15kw heat kit. HELP
So I have this question regarding how to wire up the heat package. It is 15kw with a 60amp [COLOR=blue !important][COLOR=blue !important]breaker[/COLOR][/COLOR] and a 30 amp breaker. Do I need to supply separate conductors to each breaker )ie. 6/2wg to 60 amp and 10/2wg to the 30 amp ?If so do I need 2 disconnects?
DIYFool is offline   Reply With Quote
Old 06-23-2015, 04:00 PM   #2
Rewards Points: 2,350
All the ones I've seen get a single feed big enough for both. Check the name plate, it will tell you minimum wire size. Since the breakers are built in, you don't need any disconnects.
The Following User Says Thank You to InPhase277 For This Useful Post:
stickboy1375 (06-23-2015)
Old 06-23-2015, 08:19 PM   #3
Rewards Points: 16
So how would one conductor wire 2 breakers of different amps?
Old 06-23-2015, 08:48 PM   #4
The breakers are wired together on the line side, usually.
Old 06-26-2015, 11:19 AM   #5
Rewards Points: 16
Please expand upon that if you would and pretend I'm not too brite The heat pack has 2 breakers built in (60/30amp), MCA is (55/26) What size conductor would you feed it with and how would you bridge it to both breakers? Also, could I just wire it directly to the service panel or would I need it to go through a breaker there?
Old 06-26-2015, 11:37 AM   #6
Master Electrician
Rewards Points: 5,140
Post a brand and model number, a wiring diagram or photos of the unit.
brric is online now   Reply With Quote
Old 06-26-2015, 02:24 PM   #7
Rewards Points: 542
My HVAC unit also has a 15kw heat pack. I ran two separate circuits (60A/30A) and two disconnects. The label did list "single 90A" also, but I would have had to order a different connector board inside the unit.
jreagan is offline   Reply With Quote
Old 06-26-2015, 02:49 PM   #8
Rewards Points: 16
Okay, here is as much info as I think you need....
The air handler is a Ameristar Model M4AH3036B1000AA
Heater kit is a Warren Tech Model # WHE1502BX (Product # MAYHTR1A15BKRA)
Also have a matching capacity heat pump but have the wiring on it figured out.
Included are photos of labels and wiring diagrams
Old 06-26-2015, 02:49 PM   #9
I saw one this morning that had a pair of lugs that accepted the incoming conductors. A black and red conductor left the lug block and landed on a set of double lugs on one breaker. Then another set of red and black left those lugs and landed on the other breaker.
Depending on the distance from the panel, I'd run some #2 SE cable. Feed it with a 100 amp breaker.
Old 06-26-2015, 02:51 PM   #10
It looks like it is setup for two circuits.
stickboy1375 (06-26-2015)
Old 06-26-2015, 02:52 PM   #11
Rewards Points: 16
Oh and the distance is less than 30 feet of conductor
Old 06-26-2015, 03:12 PM   #12
Rewards Points: 16
Since I already have the 60 amp breaker and conductor in place from the smaller unit that this is replacing. . . . would it just be easier (and cheaper) to just run an additional conductor (10/2) with 30 amp breaker to the unit ?
Old 06-26-2015, 05:32 PM   #13
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
yep.....
Heat Strip Wiring Question RedYucca HVAC 2 11-15-2014 05:24 AM
carrier air handler / heat pump electrical requirements Cysnake Electrical 6 05-18-2012 11:43 AM
Reducing 15kw Heat Strip tx_reeg HVAC 22 01-24-2010 10:24 AM
heat pump install wiring question fireman0175 Electrical 1 08-03-2009 01:12 AM
Help with Air Handler and Aux Heat kulkarni_ash HVAC 5 10-06-2008 09:05 AM
