Wiring Two Pole Breaker - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-24-2010, 05:33 AM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
Originally Posted by ugabulldog View Post
Also, does the white wire go to the neutral screw on recepticle, or the hot screw (brass)??
There should not be a silver screw on this (240v) receptacle. If there is you've got the wrong device.
Old 05-24-2010, 08:50 AM   #17
still needs to be water proof
The older I get the better I was
Old 05-24-2010, 01:43 PM   #18
Totally screwed together
See - THAT'S exactly why I'm worried about that!
xxPaulCPxx is offline   Reply With Quote
Old 05-24-2010, 03:54 PM   #19
So if there is no silver screw then the concept of a neutral should not enter into it.
If the idea of a white wire being used as a hot conductor is confusing to someone then maybe they should reconsider being an armchair electrician. This is a VERY common thing, there should be no concerns or issued with using a XX/2 cable for a straight 240v circuit.
Using XX/3 cable for a straight 240v circuit is wasteful, plain and simple.
And no, I am not cheap. I just despise wasting material.
Wiring a single pole switch with a pilot light gabriel246 Electrical 5 10-31-2009 06:03 PM
Double pole CH breaker ?? James Con Electrical 7 07-09-2008 11:41 PM
Three way light switches and double pole breaker ShawnColes Electrical 6 04-15-2008 08:25 PM
breaker box wiring rick32 Electrical 8 11-29-2007 11:11 AM
2 pole breaker Unregistered Electrical 3 09-11-2004 11:15 AM
