DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Wiring two light switches on the same circuit. (https://www.diychatroom.com/f18/wiring-two-light-switches-same-circuit-69584/)
Abs777 04-22-2010 10:46 AM
1 Attachment(s)
Can I pig tail from my incoming feed into two switches? Please see the poorly drawn attachment.
Thanks.
Abs777 04-22-2010 10:47 AM
I just looked at the drawing and realized that my neutral would be passed through to the lights.
secutanudu 04-22-2010 11:02 AM
You can pigtail to feed two switches like you pictured. The white wire would not be connected to the swith. The 3 whites would be nutted together (source, one going to each light).
The incoming hot would be split and to one screw on each switch. The blacks coming from the lights go to the second screw on each switch. Grounds get tied to everything and connected to the incoming ground.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
