Wiring Two 240v Appliances To One Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 08:35 PM   #1
Question
Wiring two 240v appliances to one circuit
I am trying to wire a 240v cooktop and a 240v under-counter oven but have 1 240v circuit with a 50 amp breaker. Can I wire the oven and the cooktop to the same circuit via a junction box?
Brandon
brandykn is offline   Reply With Quote
Old 02-02-2010, 09:37 PM   #2
Registered User
Termite's Avatar
You need to check each appliance for its rated overcurrent device and size the breakers accordingly. Yes, I said breakerS. Better to run separate circuits.
Old 02-02-2010, 09:44 PM   #3
I understand that in a perfect world I would run two separate circuits but can I wire them together or do I have to pay for the cost of running another circuit through finished walls?
Help on wiring and circuit breakers udfxrookie Electrical 3 07-19-2009 09:30 AM
Multiple 240V appliances wirefixer Electrical 2 03-29-2009 02:00 PM
Underground circuit to water fountain t2000kw Electrical 5 08-19-2008 08:51 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 08:38 PM
