Wiring Three Way Switches - Advice Please - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2014, 02:22 PM   #16
Rewards Points: 2,528
Originally Posted by mcnic View Post
The power first comes into the switch with a 14/2 wire. Then leaves the switch going to the light with a 14/3 wire, and then leaves the light with 14/2 wire.
In this arrangement the code police may get you because there is no neutral at the 3-way switch at the right.
But this diagram shows power into the 3-way at the left, xx/2/2 to the light, xx-2 leaving the light to power something else and xx-3 leaving light for 3-way on the right.
grounds not shown for ease of drawing
hammerlane is offline   Reply With Quote
Old 02-16-2014, 02:37 PM   #17
Here is another way that might suit you since you have xx-3 already run between the switch location and the light. This way you will need to run another xx-3 between the 3-way switch location where power enters(left switch) and the other 3-way switch location(right switch). But again there will be no neutral at this "other" 3-way location. Is it the end of the world? NO!!
grounds again not shown for ease of drawing.
You can also remark the whites being used as travelers between the 3-way switches. Mark them with black at the ends.
Obviously the difference between the 2 diagrams is whether you want to run the cable for the right 3-way switch from the left 3-way switch location or from the light location
Question on wiring two banks of lights from two switches dustycreek Electrical 3 09-09-2012 04:34 PM
Wiring switches in Ontario demandrew Electrical 4 12-14-2011 09:30 PM
Wiring 3 switches with one home run. Abs777 Electrical 2 10-19-2010 01:13 PM
Wiring fixtures when there are three way switches involved phospher Electrical 17 05-27-2009 09:56 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
